Android Single Din w/o Cutting!
Hi,
thanks for sharing this. Looks great and must be powerful enough as a good android tablet.
Do you think the screen ribbon is long enough to install the screen on a modifry bracket perhaps and then reinstall the original door to cover the naked unit?
thanks in advance for your reply.
Based on pictures from joying's website that ribbon cable appears to be a standard 40 pin IDE, used for disk drives in older computers. Those come in all kinds of lengths.
I don't have one of these units so I can't say for certain, but it sure does seem like your idea could be made to work, even if the cable it comes with is too short!
The image from Joying:
Standard IDE cable:
Hi,
The result is so-so. The modifry dash is not strong enough for this (tbh, it's kinda weak to hold just my phone, it vibrates a lot w/o providing extra support). It currently sits on two magnetic mounts, one of which is bolted to the modifry bracket. Seems stable, but not a long-term solution.
On a related note, to stock cable length is enough to reach the modifry bracket and a bit more. It's definitely an older 40-pin IDE cable. To reach the other end you'd have to disassemble the unit though.
The system can learn stock audio controls, but it's buggy at the moment. Haven't played enough with it to find a stable setting. I'll start clean tonight and add them one by one to see if maybe one button causes issues or something.
Everything except 'mute' works. Mute also kinda 'works' but somehow requires a double-click and causes the unit to randomly turn off the screen after other buttons, so it's best to avoid letting the unit learn that 'mute' button.
One annoying thing about the unit is that it has a severely limited Bluetooth stack, so internet sharing over bluetooth is impossible. Couldn't get Android auto to work either. My main phone is on Android 9, and won't connect to the Zlink app on the radio. My old phone is on 7.0, it does connect, but the Android Auto on the radio just quits when I try to launch Waze on my phone. Oh well, not that big of a deal. Picking up some USB LTE dongle, hopefully it'd work with the radio, cause manually sharing my phone
s internet via WiFi every time would get annoying.
Thanks for the info on the controls. Let me apologize if this is a stupid question, but did you end up hard wiring the Joying or did you buy a aftermarket harness to get the controls to work. If you used an aftermarket harness. where did you get it. Second, how do you program the Joying to learn the control buttons?
Programming looks mostly like parts of this video
I did get a Honda pigtail harness (Metra 70-1721 or Scosche HA08BCB) and spliced it with the supplied unit's pigtail, which has two wires for keys to be learned that I routed into pins 3 and 14 (this one doesn't seem to work for me).
The S2000's mute switch provides +12v, while most aftermarket headunits expect the mute button to switch
to ground. You can *probably* get the mute working by using a relay to switch the signal from +12v to ground (-12v).
See: https://www.the12volt.com/relays/con...g-polarity.asp
