Anyone have a trunk-mounted equalizer?
Old Jul 11, 2009 | 07:36 AM
dierk's Avatar
Default Anyone have a trunk-mounted equalizer?
If you have swapped out your stock head unit, chances are you don't have a separate equalizer.
But, if you have one anyway for whatever reason, please share your experience.
Thanks
Old Jul 11, 2009 | 11:32 PM
Claus's Avatar
check out the audio/video system sticky, there are some talks about the PXA-H100.
If you are talking about the Jurassic age slider and dial type equalizer, then I don't think anyone has one
Old Jul 12, 2009 | 06:06 AM
dierk's Avatar
Thanks, I had in mind an Audiocontrol product like the DQX or EQX
Old Jul 12, 2009 | 12:12 PM
2big4aS2000's Avatar
the audio control pieces mentioned above can enhance and correct the peaks and valleys that any car has, this is the only way to correctlye "tune" and system, your head unit cant come close to what these can do!
Old Jul 12, 2009 | 01:44 PM
dierk's Avatar
[QUOTE=2big4aS2000,Jul 12 2009, 12:12 PM] the audio control pieces mentioned above can enhance and
Old Jul 13, 2009 | 02:27 PM
Claus's Avatar
if you just want to tune the sound to the way you like it, then the two devices you mentioned would work.
However, what they are missing is time alignment, which brings huge improvements. You might want to just purchase a higher end Eclipse or Alpine hu that can works with PXA-H100 so that you can have both time alignment and Parametric/Graphic equalizer. With the tuning kit, the PXA automatically measures and adjusts the equalizer as well, and has much more adjustment points when it does auto correction.
I don't recommand EQX unless you are integrating an aftermarket system to the stock HU, but it is still a very good and solid piece. The DQX has everything but time alignment, but I'd rather spend that kind of money on a good HU or HU+Processor combo instead.
plutonium239
Aug 12, 2007 02:54 PM
Miike505
Jun 17, 2005 11:50 AM
LudeAtic
Sep 25, 2004 03:14 AM
su2ny
Apr 16, 2003 05:34 AM
ByteIt
May 12, 2002 07:23 PM
