Grounding point for aftermarket h/u
Old Sep 12, 2001 | 03:17 PM
Kibro's Avatar
Default Grounding point for aftermarket h/u
It seems that whenever I increase the volume on my stereo, all the speakers starts to produce pops. I am assuming that my ground is not sufficient (I just tapped at the factory ground wire). I have components up front and coaxs at the back. Anyways, where can I place a new grounding point in the space where the radio is? I prefer to have an existing bolt/screw so that I will just have my ground wire attached to it.
Thanks for the help.
Old Sep 12, 2001 | 03:28 PM
Pinky's Avatar
Poping sound? That wouldnt be a grounding problem. Im not sure what it is maybe the speaker is over extruding or the amp is clipping. Its most likely a ground.
Old Sep 12, 2001 | 05:32 PM
Kibro's Avatar
It is not much of a popping but more like distorted sound. You are right though, it seems that the amp is clipping. The funny thing is, I am using the internal h/u amp. I will check if the power is that I am feeding through the stock wire is enough or not.
How do you think I can go about testing this?
Thanks for the input.
ar10
Apr 19, 2015 08:37 AM
DangerZone9K
Mar 4, 2011 05:31 AM
oth
Aug 9, 2010 10:37 AM
Truvietz916
Apr 7, 2009 11:20 AM
silversonic
Nov 30, 2001 10:52 AM
