Audio System Selection
Originally Posted by GSteg,Dec 23 2004, 08:27 PM
i'm making it an issue because people just saying the yellow top are better because of so and so. Deep Cycle is a marketing tool if you agree that it's the nature of the battery to do so. I'm also making it an issue because Optima does not state that even though the battery is able to rebound into usable charge, the capacity of the battery is greatly decreased. People will often say "yellow tops are deep cycle batteries and are able to get drained completely and then recharge to full state." Which is not true unless they have one of those industrial sized real deep cycle batteries.
Supposedly it is said that the yellow top is better for system that is much bigger and bigger systems will benefit from having the yellow top because it is "deep cycle". I can introduce you to people who are in Team Gates that ran both yellow tops and red tops with lots of power and will tell you that the red top did a better job than the yellow top. If the yellow top failed on them while the red top stays intact, chances are, the red top will serve a better purpose with less than 500wrms in an s2000.
oh yea, yellow top batteries will discharge at the same rate as conventional batteries. Only difference is that the optima batteries have more available current at start up.
seriously though, after being in here actively for over a month now, i noticed they spread a lot of car audio myths. i gave up on this forum, partially. im only helping those who actually want to know some good info and are willing to listen instead of argue.
i know you know your car audio, dont waste your time trying to give them some real info.
oh yea, to those who believe in a spec/data sheet, you have a lot to learn.
What makes you guys experts??? I know you know it all and that's fine, the fact is you both can go to the OPTIMA website and read it for yourself, the Yellow top is better for cars with system mods and the like.
I quoted this right from the OPTIMA site:
"If your vehicle has a lot of accessories like running lights, high-performance stereo/AV system, winches, or hydraulics, your vehicle demands more from its battery. OPTIMA YellowTOP batteries provide the extra performance and deep cycling capability that your vehicle demands."
So please do us all a favor and listen to your friend
and ATF Kuk, please feel free to continue to spare us your company
Thanks pal
and ATF Kuk, please feel free to continue to spare us your companyThanks pal
Do you see were it says Amp-hrs... here in this forum I would "bet" 95% of people here don't care about starting amps... its a 4-cyl ya know... They car about how long the battery will last while not being charged with the car running.
The chart above shows actually shows the numbers we care about...
[QUOTE]
[B]If people are here, it would mostly likely mean they are upgrading their sound system
so again... the Red top is fine with replacing a stock battery in a vehicle with
Originally Posted by darkknight1999,Dec 23 2004, 08:42 PM
Did you even read the Optima website? ... Cause I think you need to read a little deeper
I don't need to read optima's site to find the whole truth..
Now let me ask you a question...what are the benefits of having a yellow top over a red top? Since you have read optima's site with depth, did they also point out that deep cycle batteries requires higher voltage to recharge or else the alternator might fail? Did they tell you that? Or is it that everything on optima's site is a two-sided truth? How will it benefit the electrical system if deep cycle batteries require more voltage to recharge?
Well you win Mr. Know it all. You really showed me...
Have fun kid... good luck, do me a favor and many others here a favor and spare us your company as well.
Oh and by the way smart ass I drained the battery down about 3 or 4 times last winter... and wouldn't you know I run a solid 14.4v ... just like a champ
Good call pal.
see ya later kid
Have fun kid... good luck, do me a favor and many others here a favor and spare us your company as well. Oh and by the way smart ass I drained the battery down about 3 or 4 times last winter... and wouldn't you know I run a solid 14.4v ... just like a champ
Good call pal.see ya later kid
The last resource I would use as evidence that X is better than Y is the manufactor itself. Sure they can post the peak amp/hr, but how do they behave after they are drained? You only get peak performance chart, but peak means crap anyways.
I'm no expert. I consider myself a newby. I'm just exposed to a lot of electricity where I work.
Good call pal.
Good call pal.12v battery with 50% capacity has the same voltage difference as a 12v battery with 100% capacity.
Take physics yet?
Enough with the battery debate, its a damm battery.
Yellow top, red top, black top, cherry on top who cares.
I recall this thread started to help someone decide on a stereo system.
And we did just that. ZRO keep us posted on how the install goes.
Merry christmas.
Merry christmas.
Merry christmas.
Merry christmas.
most of our debates has had pure facts behind them, yet most of the replys we get from some of you guys is crap. a lot of you believes in myths. if my information is not valued here, thats fine. ive been fine with it. im just some guy thats knows about a few things and can probably help some of you guys with your system. hell, im sure that GSteg and i, can help some of you guys build better systems that before. im also trying to destroy most of the myths around here. im sure there are a lot of myths i still do not know about, but the ones that i can identify as purely myth, i will try to give pure fact.
as seen in this thread, GSteg gave pure facts about his arguement. even said he can introduce to darkknight to a few competitors that say red top is better. he still has to argue. GSteg also talked about marketing schemes and he still had to say something back. if this was a normal conversation about marketing schemes, i bet he will agree that all successful major companies have great marketing teams behind them.
calling people kids, arguing back and forth, telling him his facts based on his very very low knowledge about voltage and capacity, this is all uneccessary. we are all car audio enthusiasts here, we all have one goal, having a great system for the amount of money we put in. there are a lot of shortcuts and tactics to that goal, if we cant all agree on that, what can we agree on.
as stated above, i feel that my information is useless here. i feel that a lot of you do not want to believe in what i say. if one of you did something wrong or was about to make a wrong choice, should i say something? i feel that most of you would not believe a word i say. think about that.
darkknight, you need to get a life. calling peolpe kid, yet you're being so damn immature about the whole thing.
