Audio upgrade. Is this plan a good one?
Old May 17, 2012 | 04:37 AM
Rilot's Avatar
Default Audio upgrade. Is this plan a good one?
I'm currently running an Alpine X305 with the Imprint module. This is fed into an Audison SRx4 amp which is in turn driving Hertz HSK-165.4 comps up front and a JL 10W0 in a custom enclosure in the trunk (3ch mode 1 x 190W + 2 x 60W @ 4 Ohm).
I'm finding that the sub just isn't powerful enough so I'm thinking about doing the following:
Ditch the JL 10W0 and replace with a Hertz HX250D (dual voicecoil)
Bridge the Audison SRx4 to 2 channel mode (2 x 170W RMS @ 4 Ohm) to drive the comps (could maybe go full active but I'm not sure I want to at this stage)
Add a Hertz HE4 amp I have spare in 2 channel mode (2 x 200W RMS @ 4 Ohm) to drive each of the 2 voicecoils in the HX250D
What do you think? Good plan or should I do something else? Bare in mind that I already own the HE4 amp which is currently doing nothing.
Old May 17, 2012 | 05:54 AM
2big4aS2000's Avatar
will your new amp bridge? because if you dont get the gains exact you will bow that sub. but your plan is good, i find those mids/highs sound way better with more power. would not go active, use hertz cross over,
Old May 17, 2012 | 07:39 AM
Rilot's Avatar
The other option is to buy another JL 10W0 and run the subs from each pair of bridged channels. Hmm, that might work better actually.
Old May 18, 2012 | 08:34 PM
etang789's Avatar
I think if you think your sub isnt powerful enough, may be look into a much more powerful amp for it!
I would get something like JL Audio HD900/5 and replace all the amps you have now. Save some space and less strain on your electrical system. Or just add a JL HD750/1.
johnqt3
Jan 21, 2008 05:43 PM
S2Kstuntin
Aug 17, 2007 04:08 PM
StEVEN_s2k
Feb 1, 2006 07:51 PM
S2k Awe
Oct 25, 2004 11:43 AM
brianhdickson
May 7, 2003 12:32 PM
