Best place under hood to grab 12v+?
Old May 4, 2011 | 11:15 PM
s4play's Avatar
Default Best place under hood to grab 12v+?
Is there any good location to grab the 12v+ for Ignition (when key is turned on)?
Figured I'd ask before we run wiring through the firewall.
thanks
rick
Old May 5, 2011 | 11:17 AM
midnightmethane's Avatar
well I'm guessing you mean grabbing power under the dash and not under the hood...since you don't want to go through the firewall
in that case a search will be your best friend...but the fuse box under the dash on the driver's side is where you'll be able to grab switched or unswitched power
Old May 5, 2011 | 05:39 PM
s4play's Avatar
No I need Ignition UNDER THE HOOD...
If inside the compartment that's easy
Old May 6, 2011 | 06:10 AM
Neutered Sputniks's Avatar
Try the underhood fuse box, check with a multimeter. All kinds of stuff that doesn't get power till ignition is on. Don't know offhand, and my battery is disconnected along with the underdash harness, so I couldn't check it out for you or I would.
ETA: Granted a lot of that stuff may have constant power and the relays aren't allowed to activate till the ignition key is on, so it might be a dead end, but it's worth a shot.
BS2K00
Feb 2, 2016 07:33 AM
boltonblue
Apr 26, 2009 02:02 PM
stormrider
Feb 9, 2005 08:26 AM
NY 04 S2K
Jul 26, 2004 11:50 AM
