Best way to add aux functionality on OEM Radio
Old Jan 26, 2014 | 07:16 PM
autoenthusiast's Avatar
Default Best way to add aux functionality on OEM Radio
I'd like to keep my s2000 100% as close to stock as possible.
Is there a way to add a non intrusive aux cable to the stock head unit to use my phone with? That is all I really need.
Something similar to what is available on E46's would be ideal. Just plugs into an existing port behind the stock headunit.
Old Jan 26, 2014 | 07:37 PM
AZH's Avatar
AZH
I used this for my iPhone. Dash controls still work room although skip fwd only. Mute, volume and source works too. Just no back or pause on the dash. It also has RCA inputs so you can use a RCA to headphone jack cable for other phones
iPhone/phone hook up
Old Jan 26, 2014 | 08:08 PM
Thanks for the tip.
I won't be using my iPhone for media.
But I found this
http://www.ebay.com/itm/USA-SPEC-BT3...item20d5fdbe31
By the same company and uses bluetooth so I can waive having cables dangling anywhere!
https://www.youtube.com/watch?v=pf55cCr_-08
EDIT:
Looks like I will be buying the BT35-HON as I just confirmed it fits AP2 S2000's
http://usaspec.com/docs/AppGuide_20131120.pdf
They also have their
PA15 HON2
that also fits S2000's
Old Jan 27, 2014 | 07:20 AM
takeshi's Avatar
There are a number of aftermarket interfaces for the stock radio. Check with the usual suspects: USA Spec, PAC Audio, Grom, PIE, etc. I don't recall off the top of my head which offer Aux.
Dash controls are irrelevant for aux inputs.
Old Jan 27, 2014 | 11:07 AM
Thanks. I ended up going with the bt35 Bluetooth interface.
S2K_Vtec
Apr 4, 2014 10:01 AM
AusS2000
Apr 29, 2013 07:28 PM
bnag0
Apr 15, 2013 04:52 PM
samg1988
Jul 6, 2011 11:07 AM
Trevi
Aug 8, 2007 12:27 PM
