brake light on dashboard
Old Oct 9, 2009 | 09:30 PM
TatWongkungfu's Avatar
Default brake light on dashboard
hey guys i just recently purchased a yellow 2001 s2000 and now the brake stays on the dash board while im still driving, the e-brake is all the way down. please help me!
Old Oct 10, 2009 | 08:05 AM
BO(RED)'s Avatar
That light comes on due to the emergency brake wire being grounded. I would remove your center console and check out the wiring around the handle, I suspect there is a short to ground in that area.
Old Oct 12, 2009 | 08:21 AM
megalomaniac's Avatar
Your brake light will also come on if you are low in brake fluid. So make sure you check that as well.
Old Oct 12, 2009 | 08:31 PM
G's Avatar
G
this is the first place I would look.
Old Oct 13, 2009 | 05:48 AM
takeshi's Avatar
IIRC fluid can be low due to pad wear as well.
Old Oct 14, 2009 | 03:40 PM
You are correct. As you pads wear, it requires more fluid to fill the space. I'd have you brakes checked first and if they are close to needing to be replaced, have them replaced. If not, add some fluid and away with the warning light.
LenS2K
Nov 17, 2012 08:05 AM
hayabusa1285
Jul 3, 2011 06:41 PM
thesilverbullet
Jan 17, 2010 12:28 PM
TatWongkungfu
Oct 20, 2009 12:07 AM
jsyang15
Jan 2, 2005 10:17 AM
