broken Focal speaker, need help
Old Dec 16, 2003 | 11:33 PM
whiteGoKart39's Avatar
after reseach for the past 2 days, i found out that my 165w midbass is broken, i think its the +,- wire (spider?) connects to the cone part came loose. is this somthing fixable? covered in the factory warranty??
Old Dec 17, 2003 | 06:00 AM
modifry's Avatar
Honorary Member
This is a fairly common failure. I've had several drivers in the past with the same problem, oddly enough two of them were Focal 8" home speakers. They sounded so good I always played them very loud and the excessive excursion just wore out the tinsel leads (the wires connecting the terminal block to the voice coil).
In some cases I have managed to repair drivers with this problem but it's usually not as good as the original because it's hard to find wire with the same flexibility as the factory tinsel. The best repairs I made used wire from CAT5 patch cords. If you are reasonably good with a soldering iron you might try to fix it yourself.
If there is no other damage to the driver you may have some luck getting them replaced under warrenty. Any of my failures were too old to bother with a warranty claim.
Old Dec 17, 2003 | 03:07 PM
is there a special type of soldering iron i should use. or maybe i should let a pro fix it? (job like this won't cost too much right?)
mr5parkle
Sep 28, 2011 02:51 PM
RL1924
Jan 14, 2010 06:22 PM
mikdys
May 7, 2008 05:01 AM
whiteGoKart39
Dec 17, 2003 03:10 PM
Hickey322
Feb 24, 2003 08:58 PM
