need help, midbass not working??
Old Dec 15, 2003 | 03:17 PM
whiteGoKart39's Avatar
my driver-side Focal 165w midbass is not working (no sound coming out of it), i checked all the connections but everything seems ok. Fade/balance is at zero, tweeters and the other midbass are all working fine, amp is good. what could be the problem here?
btw, the component is hooked to the OEM HU.
Old Dec 15, 2003 | 04:59 PM
anyone?
Old Dec 16, 2003 | 08:43 AM
jeffbrig's Avatar
Cross your speaker wires left/right at the amplifier to rule out a bad amp channel. If the problem follows the amp channel, you've found the culprit. If not, use a meter to check the resistance to through the wires and speaker. If there's a break somewhere, you'll read infinite ("OL" on most digital meters). If this is the case, you'll need to figure out if it's a cut wire somewhere or a problem in the speaker itself. You can measure resistance through each conductor separately, and through the speaker itself.
Also, if you have crossovers, you may want to swap the 2 as a test. I've personally run into situations where a wire appeared to be properly connected to a crossover, but wasn't making good contact.
Old Dec 16, 2003 | 04:34 PM
darkknight1999's Avatar
Well I'll tell you a little story..... this happened to my brother last year.
He was reworking his system again of rlike the millionth time for reference I think he's on his 7th or 8th time now...he changes it around for the fun of it.. whatever... anyway we installed a brand new set of Alpine seperates into the doors. Yes they we're wired correctly,... but a little bit of water got down into the door and "shorted" out the speaker. I tell you this story because it sounds exactly like what's happening to you. All of a sudden one day it just stopped and the only thing that looked out of place was the back of the speaker was a little damp. We checked out everything twice and it was just the speaker crapped out for some weird reason.
Moral of the story just connect another speaker to the leads in the door, if it lights up.... bad speaker
Old Dec 16, 2003 | 07:25 PM
Moral of the story just connect another speaker to the leads in the door, if it lights up.... bad speaker [/QUOTE]
im going to try that now..cross my fingers!!!
Old Dec 16, 2003 | 11:28 PM
yea, my speaker is broken.. it looks like the "+" "-" wire (spider?) that connects to the cone part is loose.
Old Dec 17, 2003 | 12:20 AM
Sorry to hear that but at least you know the culprit. You can try to bring the speaker back to the dealer you got it from and see if they can help you out in some way, unless of course you got it on the net in which your most likely screwed
Old Dec 17, 2003 | 03:10 PM
yea, turns out the tinsel leads is broken, hope i can find a way to fix it.
thanks for the help guys!
MaxAP1
Aug 23, 2017 12:25 AM
DangerZone9K
Mar 4, 2011 05:31 AM
Capcitys2k
Sep 2, 2009 12:58 AM
Brennon
Oct 11, 2006 03:44 PM
h0ckeypunk
Feb 22, 2004 06:32 PM
