Building Ported sub box for JL 10w6V2
Old Feb 22, 2006 | 11:13 PM
Wahooz's Avatar
Default Building Ported sub box for JL 10w6V2
I'm planning on building my own sub enclosure for the tool well area of my S (for a JL 10@6V2) and I'm running into a possible roadblock in the design process. I've taken all the required volumes, port lengths, cross sectional areas, etc. recommended by JL and I've come up with a design that will fit in the tool well, and still provide the required tolerances, however, the majority of the port (slot port) will actually exit the enclosure. I've looked at a bunch of websites and none of them specifically state that this will affect the design, but wanted to get some feedback here. I've not seen anyone on this site w/ a ported box so was wondering if I'm wasting my time.
The port would obviously originate within the enclosure, but to get the recommended 30" length (JL recommends), about 12" will have to exit the enclosure in a duct. This duct would make a 90 degree bend once outside the enclosure and then fire into the open area under the soft top tray.
The other option is to utilize a round port, but again, the port would have to continue outside of the enclosure.
Darknight, please chime in as I know you build sub boxes for many on this site. Thanks all-
Old Feb 23, 2006 | 09:42 AM
S2KinVA's Avatar
Give me till next weekend or so and I will have some pics of mine. My new set up will be using a 10w6. Are you glassing the trunk or MDF? The port design does not have to be the way JL shows, although that would be the most efficient. You can also run a sealed enclosure, that would produce a tighter hit vs a boomy hit.
Old Feb 23, 2006 | 09:41 PM
darkknight1999's Avatar
Ports are there to tune the FQ... but you need to run the amp at the exact power ratings as well. You can adjust the port size. You could split it up into 2 ports or even three if your design can tolerate it.
Old Feb 24, 2006 | 12:32 AM
Wahooz's Avatar
Thanks all....S2KinVA please keep this fellow Virginian in the loop on your project...very interested to see what you came up with. As for mine, I was planning on MDF for the box w/ a slot port that exits the top of the enclosure and then right angles into the open space under the convertible top tray.
Don't let the Guam flag in my sig throw you off, as my name implies, I'm from God's country! NoVA in the hiz-ouse!
Old Feb 24, 2006 | 06:28 AM
NFRs2000NYC's Avatar
Why ported? In an s2000, you are asking for more work with a port. Try a sealed box, if you dont like it, then port it.
Old Feb 25, 2006 | 03:30 AM
Wahooz's Avatar
Thought I'd go ported b/c they're supposed to be more efficient and would make better use of my amps' power. It does seem like a pain, though... I had read several posts on here of insufficient bass output from sealed enclosures mounted in the trunk well....I think my amp and sub are powerful enough to overcome that concern, though. I'd like to see what S2KinVA's ported box looks like and get his feedback on sound quality before I decide on a sealed or ported box.
Old Feb 27, 2006 | 07:44 AM
S2KinVA's Avatar
My build begins wednesday and I should have pics of the box by sunday or so...
Old Mar 6, 2006 | 02:43 AM
Wahooz's Avatar
Any update on the build? Pics or feedback on sound? Thanks
Old Mar 6, 2006 | 06:08 AM
S2KinVA's Avatar
not yet, a little behind on it... I know we will be 100% done with the car by Wed night. I will update you asap.
DRE.
Nov 26, 2006 02:29 PM
mc2
Apr 15, 2006 05:38 AM
chrisesteban
Mar 26, 2006 01:57 PM
JAPCAB
Nov 22, 2005 07:16 AM
Bonesy
Aug 10, 2002 12:18 AM
