Charging Phone Through USB in Radio
Hi All,
If I buy a radio with a USB input, will I be able to use this to charge my Iphone? Does anyone have a unit that they recommend that provides enough power?
The newer Kenwoods supply more current (1.5A) than their older ones (1A) but obviously won't be as fast as a dedicated charger providing 2.4A would be. Quick Google search seems to show that the newer Pioneers stop at 1.5A too.
Thanks! I am fine if its is slow, even if it just holds the charge id be OK with that. My cigarrete charger is busted and I got quoted about 100 for repair. I might as well buy a 100 dollar radio, since I also need a new radio anyway.
Crutchfield is a good place to research individual head units, for example this is the details page for the Kenwood KMM-BT322U:
https://www.crutchfield.com/p_113BT3...U.html?tp=5684
"Smartphone Charging: The head unit's USB connection provides 1.5A of current to power and charge your connected Apple iPod/iPhone or Android smartphone when your vehicle's ignition switch is set to the 'ACC' or 'On' position (if your iPod/iPhone has no initial battery charge, then the unit will not recognize it)."
Great resource!! So I clicked down into the links until I found this: https://cdn.discordapp.com/attachmen...44/unknown.png
So, it seems that each USB outlet can provide 1.5A, but my question is: If 2 iphones are connected at the same time (to USB1 and to USB2), does the unit provide 1.5A to each USB oultet, or does it get split to 0.75A each? I guess this is more of an electrical knowledge question.
