check engine light
Old Nov 26, 2009 | 08:59 AM
slociviccoupe's Avatar
Default check engine light
currently doing a rwd conversion on my civic with a complete s2k as a donor car.
I have the engine and all the s2k wiring in the civic. its an 05 f22c. I removed the eps out of the wiring as well as all the evap solenoids and wiring. also the air assist pump and solenoid. I get a check engine light. I did the same on my 05 s2k unplugged everything under the hood, drove around for a few miles and nothing. I haven't pulled the codes yet, but seing if removing these emmisions items will throw a code? i also removed the fuel tank pressure sensor and solenoid from the charcoal canister mounted in the rear subframe.
im just trying to get rid of the cel. guess i need to pull the codes first.
engine starts and runs just have to finish some fab work.
here is the link if interested.
http://www.k20a.org/forum/showthread.php?t=58793
Old Nov 26, 2009 | 11:56 AM
AMS MIKE's Avatar
yes you will get these codes among others i am sure:
P1456 EVAP
P1457 EVAP
P1459 EVAP
Solution....get AEM EMS! That is the best solution!
Rhodium1
Mar 5, 2019 08:06 AM
coursevector
Dec 31, 2009 02:28 PM
flopez82
Sep 7, 2008 08:03 PM
DannyInKorea
Feb 16, 2006 09:32 AM
smanders
Nov 22, 2002 11:21 PM
