Safe way to Check Engine Light
Old Nov 19, 2002 | 09:03 PM
smanders's Avatar
Default Safe way to Check Engine Light
Hello everyone,
I am writing an OBDII software tool for the PocketPC . I want to test my Diagnostic Trouble Code reader with the real thing. What is the safest way to generate a check engine light illumination on the S2k? Removing the gas cap does not work. I know removing some of the vacuum hoses will do it but I want the "safest" way possible. Also please post your past experiences with the Check Engine Light, problems and solutions. If you happen to know the trouble code, please include .
Thanks,
smanders
Old Nov 20, 2002 | 05:39 AM
Squeezer's Avatar
If you look on the front driver side of the cylinder head cover, slightly infront of the fuel rail is a sensor. If you disconnect it, the engine won't rev over 3k, and after two starts, it will generate a check engine light (don't ask me how I know this ). I don't know what code it throws though.
Old Nov 20, 2002 | 06:08 AM
RT's Avatar
RT
Unplug the MAP sensor and start the engine ........
Old Nov 20, 2002 | 08:00 AM
xviper's Avatar
Unplug the VTEC solenoid wiring harness.
Old Nov 20, 2002 | 09:24 AM
smanders's Avatar
Thanks for the responses....I'm going to give them a try tonight...
More posts are welcome....
smanders
Old Nov 22, 2002 | 11:21 PM
swtazn97's Avatar
remove you cat!!!!!! you'll definatly get a check engine light. Probably the safest way to go.
runyonwc
Jul 30, 2019 08:51 AM
a6s7d8
Mar 13, 2007 11:46 AM
DannyInKorea
Feb 16, 2006 09:32 AM
Mirror
Sep 4, 2004 10:02 AM
SilverSurfer
Oct 23, 2001 04:05 PM
