Confirm Parts List for Audio Upgrade
Old Jun 20, 2017 | 11:01 AM
compaulsive's Avatar
Default Confirm Parts List for Audio Upgrade
Like most folks I’m upgrading my head unit and speakers on my 2002 S2000. Here is the list of parts (see below) I think I need to complete the full install. I’m going to have a professional do the full install. Thanks for any help you can provide on these questions!! Much appreciated :-)
Questions:
  1. Is there something I’m missing (e.g., sound dampening material to reduce vibrations, etc.)?
  2. Will the use of a non-CD head unit open up enough space to allow for the Alpine amp (KTP-445A) to fit inside the dash?
  3. What mods are needed to install Polk Audio DB6502 tweeters and woofers?
    1. Do I need Modifry’s Plastic Speaker Rings for 6.5” drivers?
  4. Will the Pioneer TS-WH500A subwoofer fit under the passenger seat and allow the seat to still slide?
PARTS:
Alpine media player (No CD): UTE-62BTAlpine Amp: KTP-445AModifrySpeakers
Old Jun 20, 2017 | 04:13 PM
alSpeed2k's Avatar
Looks good to me. Where do you plan to install the sub?
Old Jun 20, 2017 | 05:17 PM
I’m planning on installing it under the passenger seat. I found a forum post by another S2K owner who installed it their. Unfortunately he’s pics were no longer active. What wasn’t clear from his post was if it interfered with the seat moving forward and back. If it interferes with the seat, I want it behind the passenger seat.
Old Jun 21, 2017 | 05:59 AM
Chuck S's Avatar
Got data to support this? Hard to believe over 30,000 aftermarket radios were installed S2000s in the USA alone! I'm not sure even "many" would be accurate. Does seem to be fairly common for unknown reasons (as the wind and engine noise drowns out anything our of the radio on these cars).
-- Chuck
Old Jun 22, 2017 | 07:05 AM
oth's Avatar
oth
You'll only need one pair of the speaker harnesses - they connect to the factory wiring in each door.
You'll need speaker wire to run from the speaker harness to the crossover, and from the crossover to the
woofer and to the tweeter. The wire running into the door is not very thick, so there'd be no benefit to
running fat wires within the door, so any speaker wire will do.
You'll also need
RCA cables RCA cables
to go from the headunit to the powered subwoofer, and power wire for
the sub. Maybe go with a kit like
this this
which appears to come with speaker wire too.
Hmm, I just looked up the specs, and it has a 10amp fuse, so that wiring kit is definitely overkill -
you should be able to plug it into an accessory terminal in the under-dash fuse box, if the supplied
wires are long enough.
Old Jun 22, 2017 | 01:50 PM
Thanks for the suggestions and links. I will get the RCA cables and speaker wire.
Old Jun 23, 2017 | 10:02 AM
lovegroova's Avatar
-- Chuck
I can't hear any wind or engine noise in my car with the roof down at 80mph. It's a matter of getting the right system installed.
Mish
Apr 12, 2015 04:18 AM
Equitrak
Aug 8, 2010 09:45 AM
netanderthal
Sep 19, 2007 12:34 PM
thrackley
Feb 24, 2003 06:18 PM
ianl
Jan 12, 2002 12:53 AM
