connectors questions
Old Feb 6, 2004 | 12:11 PM
silversonic's Avatar
Default connectors questions
What sort of snap/quick connectors should I use to easily connect/disconnect speaker wires?
I'm into autox and need to quickly remove the amp. So instead of unscrewing 8 speaker wires terminals, it would be great if I can just yank off some connectors.
Will this stuff works?
http://store.yahoo.com/digitalgiftworld/ib...ibcy-n-100.html
how about this?
http://www2.towerhobbies.com/cgi-bin/wti00...p?&I=LXGH95&P=Z
Thanks in advance
alex
Old Feb 6, 2004 | 03:42 PM
PJK3's Avatar
those would probably work, but they wouldn't be my first choice...
for power, try something like these:
http://www.partsexpress.com/pe/showdetl.cf...t_ID=6299&DID=7
http://www.partsexpress.com/pe/showdetl.cf...ID=118723&DID=7
and for speakers, you could do something like:
http://www.partsexpress.com/pe/showdetl.cf...t_ID=2215&DID=7
or this
http://www.partsexpress.com/pe/showdetl.cf...t_ID=2481&DID=7
http://www.partsexpress.com/pe/showdetl.cf...t_ID=2224&DID=7
http://www.partsexpress.com/pe/showdetl.cf...t_ID=2231&DID=7
we use 1/4" connectors soldered into speaker wire runs all the time for high power applications for pro audio...
Old Feb 6, 2004 | 04:01 PM
Andy Kirk's Avatar
Hi:
I would definately go with Phillips second recomendation for power connections, but as you wanted to also disconnect 8 speaker wires I would recomnend a high amperage connector that will handle 8 or more wires. I note that you are in the Bay area. Try one of the electrical surplus houses. I have used cinch Jones multiple connector disconnects in the past, the advantage is you don't have to check to see which connector plugs in which every time you reconnect. As to the input connections the 1/4 inch will work well.
Andy
Old Feb 8, 2004 | 10:40 AM
Otter's Avatar
Since you are in the bay area, you can get 0.093" molex connectors at Fry's. The 9 pole model is good for 9 A per connection. If you are worried about that, you can get one with more circuits and use two pins per wire. Fast, easy, and available.
They look like this:
http://www.ba-electronics.com/molex.htm
dlpowered89
Feb 12, 2015 09:41 AM
Rilot
Mar 17, 2012 01:42 AM
etang789
Jan 31, 2011 08:55 PM
AquilaEagle
Car Talk - Non S2000
Jun 17, 2009 01:00 PM
abv
Feb 14, 2007 02:06 AM
