Convertible Top Doesn't Work!
Old Sep 25, 2007 | 06:10 AM
chhatre9's Avatar
Default Convertible Top Doesn't Work!
Hi, I'm new on the forum and I just bought an '06 white s2k. I installed a 10 inch infiniti sub with alpine amp 220 RMS yesterday from best buy. I know some of you may tell me this was my first mistake.
This AM, it was raining outside, so I decided to drive with top up, and when I pushed the button, the top would not move! Is this is a fuse? Could something have been done during the install? I took it to dealer on the way to work and he was gonna make me wait 1 hour to look at the fuse - and he said I might have burned some wiring because I installed a sub. This seems jaded and he came off as an ass.
If this is a fuse problem, what number is the fuse under the dash? Also, will I keep having this problem?
Old Sep 25, 2007 | 06:17 AM
daktruckie99's Avatar
Did you have the console apart? You might have knocked the connection loose under the button.
Its easy to check, just pry up the console and check the connection.
Old Sep 25, 2007 | 07:05 AM
Cubs2k's Avatar
Was the emergency/hand brake set?
also.....all fuses are listed in you owners manual.
Old Sep 25, 2007 | 07:23 AM
TrackStar's Avatar
It's either an under dash fuse or if you pulled the center console up, you un-plugged the harness clip.
Old Sep 25, 2007 | 08:03 AM
chhatre9's Avatar
The center console was not pulled up. What is the abbreviation for the fuse in the manual? It's not listed as convertible top. Also, will this fuse keep blowing from now on?
Old Sep 25, 2007 | 09:19 AM
oth's Avatar
oth
under dash fuse box:
#5 convertible top control unit, keyless entry, EPS control unit, gauge
assembly
#25 convertible top control unit, ECM, gauge assembly, heater control panel
** seems like if those were blown, you'd have greater problems **
under hood fuse box:
#52 Right convertible top motor
#55 Left convertible top motor
when you pull up the parking brake, does the light on the dash come on?
Old Sep 25, 2007 | 01:28 PM
chhatre9's Avatar
Yes, the parking brake light comes on. If I blew a fuse, then wouldnt the other compenents that fuse controls also not work? Now I don't know what could be the problem since keyless entry works as well as all others. I took it to Honda dealer. Will they rip me off? They know I just had a sub put in and I fear they will blame it on the sub and not let warranty cover this (prolly is the sub installs fault)
Old Sep 25, 2007 | 04:22 PM
chhatre9's Avatar
So I got it back from dealer. Turns out that during the sub install, the speed output sensor line was cut, so the car was thinking that it was still moving and not letting the top drop. Thanks everyone for their help!
Old Sep 26, 2007 | 04:03 AM
TrackStar's Avatar
Damn rookie, how'd you manage to slice that up?
ecswtrav
May 3, 2014 05:46 AM
Booztin
Aug 6, 2010 06:59 AM
Booztin
Aug 4, 2010 12:28 PM
Booztin
Aug 4, 2010 07:32 AM
s2kkyo
Nov 29, 2007 08:22 PM
