Custom 8" Sub-Enclosure
Old Apr 6, 2002 | 07:49 PM
  #31
BAD S2K's Avatar
I have interest also. The only problem is that my CD changer is installed on that side. Will you make on for the right side also?
Old Apr 7, 2002 | 07:00 PM
  #32
RedHead's Avatar
I like this idea too. Let's see if anyone will make this work!
[QUOTE]Originally posted by silverbullet
[B]I would think that a 6" sub in an enclosure above the passengers feet would sound better than an 8" in the trunk.
Old Apr 7, 2002 | 11:11 PM
  #33
WLAURENT's Avatar
Finished it this weekend - now have sub enclosures for both sides.
Old Apr 8, 2002 | 03:06 AM
  #34
rstark's Avatar
Is there any way you could build it bigger to accommodate .65 cu/ft sealed enclosure with a 10" sub on the right side?
Old Apr 8, 2002 | 09:01 AM
  #35
WLAURENT's Avatar
The problem is the Trunk lid hinges - The only other options would be to add the volume on the back-side of the enclosure which would mean cutting into the trunk trim panel to make the most of the space. My original thought was to put a 10 in but the enclosure design would have been very complex and I did not want to cut anything (other than a small cutout for the speaker wire to go through) - The 8" enclosure is complex enough as it is.
I am installing a second 8" this week and believe I will have better sound than a single 10" - will post an update when completed.
Old Apr 9, 2002 | 10:40 AM
  #36
hc68's Avatar
Nice install! I am also thinking about making a custom enclosure for a 12" JL W0 driver I already have (maybe it can fit in the bottom of the trunk?), and I was wondering where could I get some guides for first timers in working with fiberglass?
Old Apr 9, 2002 | 01:18 PM
  #37
WLAURENT's Avatar
[QUOTE]Originally posted by hc68
[B]Nice install!
Old Apr 9, 2002 | 04:52 PM
  #38
lucid's Avatar
[B]Nice install!
Old Apr 9, 2002 | 05:35 PM
  #39
Flyerst's Avatar
Just a thought ...
In another thread that is currently active, someone is talking about Blaupunkt's new saucer subs. I wonder if they could be used in your custom box perhaps with some advantages?
https://www.s2ki.com/forums/showthread.php?...&threadid=55572
Old Apr 10, 2002 | 10:40 AM
  #40
WLAURENT's Avatar
[QUOTE]Originally posted by Flyerst
[B]Just a thought ...
