Dash Lights and Keyless Entry not working
Old May 20, 2009 | 11:33 AM
chamorru's Avatar
Default Dash Lights and Keyless Entry not working
Ok, I bought a wiring harness from best buy and I wired up a Kenwood HU in my AP1 s2k. Everything is working as far as the system/subs/amp however I have lost my keyless entry and my dash lights are out. All other electrical systems are functioning correctly like my lights, turn signals etc.
I noticed on the wiring harness/adapter that there are wires for "dash illumination" and "dimmer". Since they aren't color coded to the kenwood harness I left them alone.
Does anyone know where the "dash illumination" and "dimmer" wires are supposed to be tapped into the kenwood harness? There aren't any corresponding wires to match up. The only loose wires from my kenwood harness are the antenna/rear speaker wires since i have no power antenna and no rear speakers (sub is running from pre-out)
Can anyone help me troubleshoot as to why I lost my keyless entry and dash lights? My guess is I need to splice these 2 wires somewhere I just don't know where....
Old May 20, 2009 | 11:54 AM
chamorru's Avatar
some help from the electrical wiring gurus would be much appreciated as search results have turned up little help....
chamorru's Avatar
the faq didn't help either, at least not w/ troubleshooting my issue anyways...
Old May 20, 2009 | 11:55 AM
chamorru's Avatar
perhaps i blew a fuse or 2? i'm just guessing at this point lol...help me out guys.
Old May 20, 2009 | 12:58 PM
chamorru's Avatar
OK, i'm gonna check the fuses and my ground tonight but if anybody has any possible clues or insight then please offer it up...
Old May 20, 2009 | 01:17 PM
DFWs2k's Avatar
lol...calm down dude, it's only been a couple hours
Old May 21, 2009 | 05:27 AM
chamorru's Avatar
i ended up pulling the fuses for the keyless and the small light fuses and could clearly see they were both blown. i replace them and purchased a 20 piece fuse replacement set since i'll probably need them later on anyways..
for any future noob installers out there (like myself lol)...if you're confident you wired it up right then simply check the corresponding fuses located in the under dash fuse box to see if they are blown. if that doesn't solve the problem then yea you probably need to look at your wiring throughout your system
i'm no expert though so take my advice w/ a grain a salt
Nick_K
Nov 29, 2015 03:14 AM
Nick_K
Nov 29, 2015 03:13 AM
pwr2al4
Jan 31, 2014 12:37 PM
sillyboybmxer
Nov 25, 2011 04:30 PM
PSmith67
Mar 25, 2007 03:32 PM
