Deadener--Where is it needed, liquid v. mat, best brand?
Old May 13, 2003 | 08:37 AM
b0mbrman's Avatar
Default Deadener--Where is it needed, liquid v. mat, best brand?
Hi,
I just put in my new system yesterday and it sounds great but when I turn it up, the trunk rattles like crazy. Of course, sound deadener is the answer but I've got some questions about it...
Where do I need it? I know the trunk lid for sure but is it important to have it on the sides and underneath the sub box on the trunk floor? Another related question is how many square feet do I need?
It seems there are two types, liquid and mat (and mat can be broken down into the "extreme" type or the "lite" type). Which is better for my application?
Also, there are a lot of brands out there covering a big price range. Are there any significant differences between the brands and is there any one "best" brand?
Old May 13, 2003 | 06:59 PM
chipperman's Avatar
All of the mats are rebadged from the sound industry. I bought a roll of deadener in bulk for about 1/6 the cost of Dynamat. You do not need to cover all surfaces. Small pieces about 6" by 6" work well when properly placed. Knock on the surfaces with your knuckle and listen for the loudest or loosest part. Then stick a piece there. Actually very little is needed. The sellers of this stuff would like you to buy a lot of it. Not needed. What does work really well is acoustic foam. It cancels the annoying high frequency noises that drown out sound. Once you nail down the trunk rattle, try putting foam behind the door panels. Very light and makes a big difference. Hint: Go to an aircraft upholstery shop. They use this stuff on custom jets and will cut and sell you pieces for not too much money. Good Luck. Also, you won't need a huge amp to overcome all the noise.
Old May 14, 2003 | 08:35 AM
mas's Avatar
mas
Check out the following:
https://www.s2ki.com/forums/showthread.php?...?threadid=96406
https://www.s2ki.com/forums/showthread.php?...?threadid=57404
https://www.s2ki.com/forums/showthread.php?...threadid=101606
Pretty much all rattling issues are discussed here. The S2k is pretty well constructed otherwise. I did not need any sound damping material for the trunk. I did use the dynomat door kit for the fronts.
Good luck!
Old May 14, 2003 | 09:07 AM
b0mbrman's Avatar
Dang...I combed through dozens of "deadener" and "dynamat" results but didn't think to search for "rattle." Thanks
s2k_2fast4u
For Sale
Aug 23, 2010 03:20 AM
s2kjersey
Jun 13, 2007 02:34 PM
NO RIDE
Jun 14, 2006 07:22 AM
amartin
Aug 4, 2001 08:16 PM
