DIY courtesy and footwell LED lighting guide
Old Oct 25, 2006 | 07:12 PM
Spec_Ops2087's Avatar
Default DIY courtesy and footwell LED lighting guide
DISCLAIMER: The procedures, methods and products written up here was for my circumstances only. I make no assertions that your results will be the same nor do I claim that this is the best way to do it. USE AT YOUR OWN RISK!
Well I finally found some time to write up my DIY on how to wire up your s2000 with LED courtesy lights and LED neon footwell lights. Feel free to add this into the FAQ.
Tools you will need:
~35 feet of 20 gauge wire (purchased at radioshack)
Wire strippers
Electrical tape
3m Outdoor double sided tape (purchased at home depot)
A flashlight
2 LED clusters for your foot well
4 LED waterproof LED clusters for your puddle / courtesy lights
1 relay (bought at radioshack, here is the LINK on which one you need. When you go to get it, make sure it has 4 pins on it labeled 85,86,87, 30/50)
You can buy the LED cluster from HERE Get the "ALM series Accent Light Modules" since they are waterproof, bright, durable, small, and I used them
I first decided to install the interior LEDs. The first thing you must do is to take apart the interior panels and DISCONNECT your negative battery terminal! You must remove the panels to the sides of the seats. You will also have to remove the driver
redleader
Nov 17, 2014 05:55 AM
archtop
Apr 25, 2009 11:44 AM
Spec_Ops2087
Mar 23, 2009 12:25 PM
fadiss2k
Mar 5, 2006 02:33 PM
TrIcKeD_oUt_s2K
Jun 29, 2003 09:58 AM
