DIY headunit install for ap1?
Old Jun 15, 2008 | 08:42 AM
Ludeboye1's Avatar
Default DIY headunit install for ap1?
Found one for ap2 is this the same for an ap1? I am using a dci plug and play harness with svc
https://www.s2ki.com/forums/index.php?showt...0&#entry8103771
Someone help please quick I am getting anxiousss lol
Old Jun 15, 2008 | 10:20 AM
kenta's Avatar
"To remove the head unit:
Put the shifter in reverse (to get it out of the way)
Carefully pry out the vent/door cover. Start at the top. When that's loose, open the door and gently, but firmy, work the cover loose and off.
Undo two screws at each side of the head unit."
Suggestions:
What I usually do is remove the shift knob to make more room, takes about 10 seconds to do. Then cover the shifter with a microfiber towel (or rag) to prevent it from scratching anything.
When pulling off the cover I lower the door, grab the door and pull the right side till I hear a pop, repeat for the left side.
Old Jun 15, 2008 | 11:21 AM
Ludeboye1's Avatar
How do I pry off the vent door cover do I just pull the radio door?
Old Jun 15, 2008 | 11:22 AM
Ludeboye1's Avatar
The steps are same for the ap1 as the ap2 right with the exception of the airbag wire?
Old Jun 15, 2008 | 12:30 PM
Ludeboye1's Avatar
I cant seem to get the vents on top of the radio door off, how do I do this or do I even need to?
Old Jun 15, 2008 | 05:38 PM
SupeR_DavE's Avatar
Yes u do need to get the whole piece off,I just opened the radio door,and gave a slight tug and the bottom side poped then I grapped behind where it popped and pulled again and the top with the vents popped right off
Old Jun 16, 2008 | 04:29 AM
Ludeboye1's Avatar
Thanks guys got it installed but am really dissapointed, the Cda 9886 dosent have an option to change the blue lights on the buttons to red, and I just cant stand blue argh.
Old Jun 16, 2008 | 04:33 AM
Ludeboye1's Avatar
Just a word of caution for people looking to purchase the 9886 thinking the button's can change colour.
The us model Cda-9886 dosent have this feature and is stuck to the blue illumination.
The Uk model Cda-9886R can change colours to blue/red/orange/green.
Wonder if slapping on a 9886r face plate on an 9886 would work anyone tried this?
http://cgi.ebay.com/Alpine-Faceplate-CDA-9...id=p3286.c0.m14
Old Jun 16, 2008 | 04:51 AM
NFRs2000NYC's Avatar
Read the FAQ. All the info you need is there, including instructions to remove every panel in the interior.
vbb
Jun 18, 2021 04:34 PM
Do Work
Apr 20, 2011 08:41 AM
VGS
Mar 20, 2007 05:30 PM
Rusler Firbrand
May 16, 2005 12:33 PM
