Do I need crossovers for 04 tweeters to work?
Old Jun 8, 2005 | 07:24 AM
What The's Avatar
Default Do I need crossovers for 04 tweeters to work?
Hi Guys,
I have an 01 with Infinity Reference 6002si's in the door. I just recently purchased 04 door panels and they came with the stock 04 tweeters mounted also.
I was going to replace them both with Infinity 6000cs (components), but to save a little money first, I wanted to see if I could wire up the stock 04 tweeters. Would I need a x-over in order to hook them up to the existing coaxes?
What's the best way to hook these up?
Thanks!
Old Jun 8, 2005 | 07:55 AM
jasonw's Avatar
You def. need a cross over for the tweeters. Might be able to get something cheap at Radio Shack.
Old Jun 8, 2005 | 08:28 AM
Andy Kirk's Avatar
Hi:
It is p[ossible that there is a "bass blocker" in the wire to the tweeter already, I think that whter was one in my 03 in the wiring to the tweeter. It looks like a little blue rectangle. It is a capacitoe that only allows the treble frequencys through to the tweeter and keepa the lower frequencys away. This is a cheep alternate to a crossover.
Andy
Old Jun 8, 2005 | 10:03 AM
CrazyPhuD's Avatar
Someone check the Helm manual but I don't believe the stock MY02+ systems have any sort of crossover built into the system, it is a direct conect. Filtering may be handled by the tweeter itself. While a crossover is preferred it does not appear to be required here. Check the manual for wiring diagrams to be sure.
Old Jun 8, 2005 | 10:26 AM
jasonw's Avatar
There might also be a capacitor wired onto the driver, to which the tweeter is connected.
Old Jun 8, 2005 | 10:43 AM
Willie Gee's Avatar
i tend to agree with jason. there's got to be a capacitor in there somewhere, essentially blocking the low and mid frequencies from going to the tweeter.
my fear (and it is highly unlikely) is that the capacitor is wired up closer to the source, and that when you wire in the tweeter you are going to blow it. no worries though, you are getting proper crossovers and tweeters soon anyway.
what headunit are you running? and do you have an amp?
this is important.
Old Jun 8, 2005 | 11:12 AM
CrazyPhuD's Avatar
Ahhh found the old topic I remembered....much discussion has been made about it. I think the consensus was that the hi pass filter is attached to the tweeter not in-line with the wire, but I haven't pulled my wires to see. If it is in the wiring, I would believe that it's in the helm manual wiring digrams, but if it's in the tweeter there may be no reference to it except by visual inspection.
Couple links...
https://www.s2ki.com/forums/index.php?showt...eter++capacitor
Old Jun 8, 2005 | 01:40 PM
What The's Avatar
this is important.
Thanks for the advice guys.
I'm running a cheapy DEH-P4600MP that's 50 x 4, no external amp and no plans to run one.
Old Jun 8, 2005 | 01:46 PM
Willie Gee's Avatar
you should be fine with your speakers.
thanks for the links, crazyphud!
PhenomS2k
Nov 14, 2005 07:31 AM
PhenomS2k
Oct 1, 2005 09:00 AM
lude2S
Jul 8, 2005 10:01 PM
ThaWyze1
May 17, 2004 10:30 AM
SS2000
Nov 22, 2003 05:18 PM
