Does it make a difference if you top mount or bottom mount a sub?
Old Mar 4, 2004 | 06:46 AM
Ajjra's Avatar
Default Does it make a difference if you top mount or bottom mount a sub?
When mounting a sub in an enclosure, does it make a difference if you top mount or bottom mount the sub? (assuming there is enough room to do it) Does it sound different?
Old Mar 4, 2004 | 07:08 AM
audiofreak's Avatar
do you mean facing up or down in the toolwell or just in general
subs fire backwards, so facing it up will disperse the sound better in the s2k as the sound will travel down into the toolwell and "bounce" out all over, likewise with the sidemounted 8"s firing back and bouncing out
it should sound louder and deeper overall better to have it firing down or sideways (ideally facing straight out but that isnt really feasible in the S)
You also get to see the sub
Many home stereo subwoofers fire downwards to fire the sound into the ground and disperse it throughout the room, if you know what to listen for front firing subwoofers can be "aimed" at certain parts of the room
On an additional note however I believe that you can change the phasing on some amplifiers to have the sub fire up to 180" out of cycle and in "reverse"
Does this answer what you were aiming for
Old Mar 4, 2004 | 08:00 AM
Ajjra's Avatar
This is not what I was asking but it sure was interesting to read.
I was just asking when I bolt my sub to the enclosure, is it better to slide the speaker into the top panel from the top and screw it down or to put the sub under the top panel and bolt it to the bottom of the top panel. Either way the sub fires in the same direction...
Old Mar 4, 2004 | 08:07 AM
NFRs2000NYC's Avatar
That doesnt matter, bolt it from the top, not from the inside. I thought you asked what audiofreak thought.
sdosmil77
Dec 9, 2011 03:02 PM
JSWhaler
Feb 10, 2008 04:33 PM
S2KRAZZI
Socal Swap Meet
Apr 14, 2006 07:29 AM
YOD88
Aug 18, 2004 12:42 PM
BlkMagic
Sep 24, 2003 10:53 PM
