Does the S2000 throw any OEM-specific CEL codes to indicate a problem ?
Old Dec 8, 2011 | 07:51 PM
s2kdriver80's Avatar
Thumbs up Does the S2000 throw any OEM-specific CEL codes to indicate a problem ?
Does Honda have any manufacturer-specific codes that are ever thrown when the CEL comes on?
Old Dec 8, 2011 | 08:30 PM
T-Smac's Avatar
Codes that throw the CEL light are done so because there is a problem that could be affecting emissions and therefore must be generic. I know of no codes that aren't generic that throw the CEL on.
Old Dec 8, 2011 | 08:35 PM
Sorry for the ignorance. I thought CEL codes that start with "P1xxx" are OEM-specific (as opposed to P0xxx). Reason I'm asking is, it seems like more advanced and expensive OBD2 scanners can read "OEM enhanced" DTC codes and am wondering if they are worth it over the bare bones scanners.
Old Dec 8, 2011 | 09:16 PM
T-Smac's Avatar
Disregard that, I was thinking only generic codes set the CEL because they are all emission related, but some manufacturer specific codes set them too, such as P1121 (TP sensor low). I had a DTC on mine a few weeks ago that was manufacturer specific and didn't throw a code.
Old Dec 8, 2011 | 10:06 PM
No problem. You mean you had a CEL from a manufacturer specific code, but your OBD scanner didn't recognize it?
http://www.auteltech.com/ms310.htm
That scanner claims to read both generic and manufacturer codes (e.g. "P1xxx"). Would that scanner have properly read your CEL code?
Old Dec 8, 2011 | 10:20 PM
T-Smac's Avatar
Sorry I was unclear. What I meant, was, I did not have a check engine light but when I went into my data stream just to look around, I found there was a DTC that was a P1xxx. I had a code but no light. The light is functioning properly though because during a compression test (running) I got a check engine light.
Old Dec 8, 2011 | 10:28 PM
Ha I think I got it now. Let me see if I understand it finally. All CELs give generic codes. However, if you hook up an OBD scanner capable of picking up manufacturer specific codes, you can retrieve those codes if there indeed is a problem (like what happened in your case).
xristoforoS2000
Κινητήρας - Μετάδοση - Περιφερειακά
19
Jun 2, 2018 12:20 AM
folex187
Nov 11, 2005 02:35 AM
