Door Lock/Unlock 2 Empty Pins not working?
Hey so I searched the forums entirely, and I tried plugging in wires into the keyless module entry grey connector which I mean I cannot see how that would work. Both female, and make are have the 2 empty pins. I tried putting a wire and grounding through both female and male. Still not working! I can open the box and solder the keyless module but seriously would like to avoid doing all that.
Anyone have a more indepth explaination? My car is MY00.
Read this page but no luck.
https://www.s2ki.com/s2000/topic/920...-3303-install/
Ok, first of all, I know nothing about this, but since no one who does has chimed in, I will.
From the writeup/pictures you referenced, it looks as if the grey connector has female pins,
while its mate has the male pins. I believe the writer was suggesting folding over a piece
of (stripped) wire and inserting it from the side the wires are coming out of in the hope that
it will make contact with the male pin on the other connector.
An alternative, more robust solution is to find a piece of wire with an appropriate matching
female pin and add it to the connector.
Hard to tell from the photo, but it looks similar to the stereo connector - you could get
a reverse harness adapter like the Metra 71-1721 and cannibalize it; I've also heard
those pins can be found in an ATX PC power supply if you have some old junk lying around.
From the connector, I can not see how adding any wires would help. Both slots are empty and have absolutely no wires going to any of them. It's like I'm sticking wires into a plastic hole and expecting something to happen.
usmarinedelta
Sep 29, 2015 09:19 AM
