Door Speakers in 2000 s2k with 2002 head unit???
Old Jan 1, 2003 | 04:27 AM
holtz's Avatar
Default Door Speakers in 2000 s2k with 2002 head unit???
i am planning on replacing the 2000 stock door speakers. i have upgraded to rear 3way kenwoods and 2002 head units. do i want 2way or three way door speaaker upgrade?? would prefer drop ins but if lucid adapter works will consider other speakers. want to avoid any unwanted vibration and rattle issues. thanks for your assistance.
Old Jan 3, 2003 | 06:28 AM
redhotfire's Avatar
I too have installed Lucid rear speakers and am wondering, along with holtz, what type of door speakers to purchase to replace the stock ones?
Old Jan 3, 2003 | 10:14 PM
samkwon's Avatar
Personal opinion, if you're looking for simple, inexpensive, and just more sound, go with the 2-way drop ins.
I went with the Kenwood 3-ways in front and rear, only because I felt like it and I could. On the front, much better and more sound at the same volume settings compared to OEM but, I have a friend (now a former S2000 owner, for him) that went with 2-way drop ins, also Kenwoods, up front (no rear speakers)...when comparing his fronts to mine, the only real difference was mine had a bit more bass and slightly more volume. Of course, the real difference came when I kicked in the rear speakers; no comparison then.
I also used Lucid's door adapters for fronts; no issues with rattles or vibrations at all volumes. With Kenwood speakers, you get distortion, probably because of lack of damping when you get the bass around +4 to +5 so I just don't set bass that high. I could probably take it back apart and put some damping in to fix that but honestly I'm happy with it the way it is. No point in going overboard.
Old Jan 8, 2003 | 07:47 AM
b0mbrman's Avatar
Would the 2002 HU make that much of a difference? Could a decent system w/rears and a sub be built off of it?
Old Jan 8, 2003 | 08:12 AM
Woodson's Avatar
10 watts peak. (2000 = 20 watts peak, 2002 = 30 watts peak).
Depends on your definition of decent. According to mine, no.
Old Jan 8, 2003 | 08:19 AM
b0mbrman's Avatar
Hmmm...
Well, a good measure for me would be this:
I'd like it to sound as good in my car with the top up as it does in any other fixed-roof car out there with a stock system.
Old Jan 8, 2003 | 10:54 AM
darkknight1999's Avatar
I just thought I'd show you mine. We installed Alpine SPX-177A's 6.5 in the doors and Alpine SPX-137A's in the rear panels. The crossovers will be mounted in the trunk but the fiberglass mount isn't done yet. This is an ongoing winter project. Tell me what you think.
This is before I started:
I had to cut the back of the woofer basket off.....Dremels are great!
I fit the new Alpine tweeter into the stock tweeter pod:
The woofer fit nicely into the door:
The door panel after the install:
Close up of the tweeter:
Close up of the rear install:
And yes I did have to cut a little of the metal away.
Full rear pic:
Please comment on the install. We ran all new wiring for each location. We used a Pro Audio 4 conductor 12 gauge twisted cable to cut back on having to run multiple cables to one location.
Anyway let me know what you guys think.
Old Jan 8, 2003 | 11:17 AM
SC_Highlander's Avatar
Looks good! I considered doing the same thing with my Adire Koda's tweets, but opted to put them inside the stock pod (with a little modification). What's feeding the speakers?
Old Jan 8, 2003 | 11:46 AM
I will be feeding them with an Alpine MRV-F340 4/3/2 Channel Power Amplifier.
Old Jan 8, 2003 | 12:44 PM
Bass's Avatar
John
like everything else in your car this install looks great
nice work
best
Bass
