Elemental Designs e8A.44 update
Old Jun 3, 2003 | 02:55 PM
  #151
WLAURENT's Avatar
Actually I am at 5 to 1 - 2x50 for my fronts (or rears) = 100W and 400 - 500W for my subs.
They might want you to max each channel as to prevent the amp being unbalanced. I have heard that even Adcom's home equipment does not like being unbalanced.
Old Jun 3, 2003 | 04:11 PM
  #152
PJK3's Avatar
[QUOTE]Originally posted by WLAURENT
[B]Actually I am at 5 to 1 - 2x50 for my fronts (or rears) = 100W and 400 - 500W for my subs.
Old Jun 3, 2003 | 04:24 PM
  #153
mgiang7's Avatar
[QUOTE]Originally posted by PJK3
[B]
btw -- i now know what the e8a sounds like when the voice coils bottom out....
Old Jun 3, 2003 | 05:43 PM
  #154
PJK3's Avatar
[QUOTE]Originally posted by mgiang7
[B]
i don't know if the class D will help that much.
Old Jun 3, 2003 | 05:47 PM
  #155
SC_Highlander's Avatar
You know what you need to do -- add another e8A and the nine.1 amp from eD!!!
Old Jun 3, 2003 | 06:23 PM
  #156
mgiang7's Avatar
if he could fit, yeah that's a great idea that amp is around 1000 watts @ 1 ohm
and to be honest, i bet you could sell that Kicker amp for decent money, there are still people out there that revere that amp, as they should those amps are very good.
but i wouldn't give up just yet, i think some active cooling should help things.
Old Jun 3, 2003 | 06:51 PM
  #157
PJK3's Avatar
ooooooo......
Daddy likes.... of course, Momma doesn't.
i wonder if i could overclock it and water cool??? i bet i could get an air cooled radiator mounted somewhere and a little pump... (*trails off...*)
i'm thinking active cooling is probably going to be my answer. even if i have to rebuild the amp rack top, add some ports for fans, and cut back on the plexi. i've got enough MDF and carpet for another top. i have the hardest part figured (size and curves), so it's just a matter of cutting out fans...
i'm going to see if i can solve it w/ some spacers and that one fan... we'll see...
Old Jun 3, 2003 | 09:05 PM
  #158
soons2k's Avatar
im thinking now that i need more power for my e8, or do an in cabin install. because i hooked my e8 up to my amp, but w/o a box just to see if it worked ok. and it barely moves, at levels my 10" goes crazy. the sub seems like itd definitly be suited for an incabin install and more power.
Old Jun 4, 2003 | 05:30 AM
  #159
PJK3's Avatar
[QUOTE]Originally posted by soons2k
[B]im thinking now that i need more power for my e8, or do an in cabin install. because i hooked my e8 up to my amp, but w/o a box just to see if it worked ok. and it barely moves, at levels my 10" goes crazy.
Old Jun 4, 2003 | 07:08 AM
  #160
PJK3's Avatar
[B]
