Fast and Furious electronics
Hi all,
I was wondering... in the first drag race (Vin Diesel, Paul Walker, and some other dudes, 4 in a drag)... you know how Paul has a laptop connected and everything. Is that real? I remember it has all sorts of real-time stats, and it alsohad the "manifold warning" or something like that when he was pushing it.
Has anyone ever done this type of thing? I know we can have a laptop analyse results after-the-fact, but if we could plug into it like that... think about that.... especially forpeople with LCD monitors in-built into the car. That would be very good eye-candy
I'm drooling just thinking about that...
Real-time dataloging has been around for years, but leave it to the movies to over-embelish it
You can get all kinds of pretty graphs and dials on the screen, but you'll never get a warning saying "eminent danger to your manifold" since the computer has no idea how to run a metalurgical analysis of your manifold...at best it could give you a warning if you go above a certain temp that YOU set, and even THEN it doesn't say whather or not the manifold is going to go.
But if all you want is eye-candy, you could have the LCD show you anything you want, even if it's just to scare the unsuspecting passenger.
You can get all kinds of pretty graphs and dials on the screen, but you'll never get a warning saying "eminent danger to your manifold" since the computer has no idea how to run a metalurgical analysis of your manifold...at best it could give you a warning if you go above a certain temp that YOU set, and even THEN it doesn't say whather or not the manifold is going to go.But if all you want is eye-candy, you could have the LCD show you anything you want, even if it's just to scare the unsuspecting passenger.
Dammit... well, I suppose you could set things like oil pressure, oil temperature, etc. and if a combination goes over the pre-determined threshold, then you get an "Engine Overload warning" or something like that ;-)
But does the S2000 have a "data port" like they do in BMWs, so that with the correct laptop software and cable, you can get all the stats directly from the ECU?
You can get quite a bit of info from the OBD-II interface (speed, RPM, intake air temp, etc...) - however, the communications can be a bit slow and the protocol was really designed for trouble-shooting.
I am working on a rolling dyno software package that uses the OBD-II port connected to a laptop. Testing (was out this evening running some tests on a back road) looks promising, but I have to due considerable debugging to ensure clean reliable data. The only promising thing is that my peak HP is always right on (within 2%) to my RWHP on the dyno a few weeks ago.
For in depth data you would really need a dozen or so sensors and an data aquisition card + software.
spidsey
Feb 3, 2003 04:27 AM
