Focal?yes or no
Old Mar 22, 2003 | 09:48 AM
  #21
mas's Avatar
mas
If the crossover allows, try setting to -4db. This would help, it's also the recomended setting (at least on the polykevs) when you have the tweeters so distant from the woofers. The amp sounds ok. Other than adjusting the crossover, you'd need to try what I suggested in #1 & #2.
Good luck!
Old Mar 22, 2003 | 09:52 AM
  #22
Speedracer's Avatar
[QUOTE]Originally posted by whiteGoKart39
[B]I went to my friend's shop to check out some speakers, my friend recommended me with Focal Utopia line which are 180 W and 165 W3.
Old Mar 22, 2003 | 10:49 AM
  #23
Tiger8119's Avatar
I would also recommend the Diamond Audio's
Old Mar 22, 2003 | 11:42 AM
  #24
whiteGoKart39's Avatar
Good luck!
thank for the help! i just now tune the xover down to -4, it definitely helped!!
**but its make some noise even when the headunit is off ,, is this normal??
Old Mar 22, 2003 | 01:29 PM
  #25
mgiang7's Avatar
are you picking up noise if you unplug the rca preamps from the amplifier? sounds like interference at the amp side. what kind of noise is it?
Old Mar 22, 2003 | 01:53 PM
  #26
mas's Avatar
mas
Cool.
For the noise, take it back to the shop and let them figure it out. They might have gone the easier route when installing the amp. It might be that the amp's power is triggered by the accessory switch rather than the HU turning on. Someone who's using stock HU with an amp may be able to help you here. Most aftermarket HU's have a remote turn on lead that turns the amp on/off with the stereo. I don't know how this is taken care of with the stock HU, don't think it has a remote turn on lead?
Old Mar 22, 2003 | 01:57 PM
  #27
145's Avatar
145
When I was using my stock HU, I tapped the power antenna wire, and used that as a remote turn-on. It works whenever the HU is on, not just when the radio is selected.
good luck,
gil
Jooboy
Mar 3, 2007 10:21 AM
stcsmu
Feb 12, 2003 09:53 AM
Draco
Sep 6, 2002 07:01 PM
ACB
Sep 27, 2001 07:55 AM
Chiman
Feb 27, 2001 02:19 PM
