Fuel Pump Kill Switch information?
Old Mar 15, 2009 | 07:25 PM
Neutered Sputniks's Avatar
Originally Posted by 2big4aS2000,Mar 15 2009, 10:46 PM
you could use the cigarett lighter as a switch, take it with you and car would not start
That's freakin awesome! Never thought of wiring it like that. I had been tempted to pick up an '06+ center console and using the VSA switch for this, though.
Using 8ga to the stock fuel pump would probably be overkill. I wouldn't recommend bothering with doing this unless you're planning on running a hardcore fuel pump later on (to back up a turbo/SC kit).
Old Apr 9, 2009 | 07:25 AM
camuman's Avatar
ok just to refresh me, relay has power/ground for relay. power that passes thru relay for my pump, and a wire for turning relay on and off.
sound right? i need to do something like this. s2k is way to easy to steal
Old Apr 9, 2009 | 07:21 PM
2big4aS2000's Avatar
on a standard bosch style relay you have 5 post, 2 for triggering relay +&-) and then 2 connected until relay activates connecting one of the first to the the last post
http://www.ado13.com/techs/relay.htm
Old Apr 10, 2009 | 06:38 AM
camuman's Avatar
nice, thanks for the link. going to radioshack to pick up a relay. 40 amp relay is way more then enough?
Old Apr 10, 2009 | 12:26 PM
SgtB's Avatar
You could use a 15A. It's easy to figure the load on an automotive relay. Just check the fuse size for that circuit in the fuse panel.
umair
Jul 19, 2015 06:05 PM
riceball777
Jun 14, 2015 02:49 PM
Dize
Apr 10, 2014 06:25 AM
Ek_Jak
May 19, 2010 02:42 PM
tetsuo73
Mar 22, 2005 05:30 PM
