Gauge Lights (And Dimmer Switch) Question
Old Jan 11, 2006 | 07:42 AM
JDMpress's Avatar
Thumbs up Gauge Lights (And Dimmer Switch) Question
I know it's not really S2000-related, but I was hoping to just get some general knowledge, and Honda-Tech isn't helping me out too much...
My bf's gauges won't light up. He has a 92 Honda Civic. I was trying to test it out yesterday, and I found two wires that I thought were connected to the gauge lights. When I measured the voltage when the headlights were off, it was 0. And when I measured it when the lights were turned on, it'd be close to 12V. But when I hooked up a little bulb, it wouldn't do anything. But this bulb worked perfectly fine when I hooked it up to a different circuit. What could be causing this?
I was also thinking the whole problem with the gauges not lighting could be due to a problem with the dimmer switch. There are three wires coming out of it. One is black, one is red/black, and one is red. Today, I was checking the continuity of the red/black wire and found out it's somehow connected to the black one, which I assume is ground. I'm not an expert with electronics, but for some reason, I feel like that doesn't seem right. Unless that is something that has to do with the dimmer switch. Can someone tell me if that's normal?
Jean
Old Jan 13, 2006 | 03:23 PM
MacGyver's Avatar
Those two wires may only be supply a switching signal (low-current) rather than the actual power... if that's the case, they probably do't have the power to light a bulb.
Do not quote me on this, and I take no responsibility if you blow a fuse (or something worse), but the black is most likely ground, red is power, and red/black is a switching signal.
lotus7racer
Jan 24, 2014 06:09 PM
archtop
Apr 25, 2009 11:44 AM
flexer
Feb 1, 2009 07:10 AM
scott2055
May 5, 2008 09:16 AM
bronzed
Sep 20, 2004 08:58 PM
