Grounding Amps
Old Dec 26, 2007 | 04:57 AM
Doug1627's Avatar
Default Grounding Amps
Hello,
I have 2 Diamond Audio amps hooked up in my car. When I ground them should they both ground in the same spot?
Old Dec 26, 2007 | 12:19 PM
smurf2k's Avatar
thats fine
Old Dec 27, 2007 | 08:55 PM
IShift@9v3's Avatar
Banned
It's almost required. Straight sub amps are a little more forgiving as far as ground loops go, which cause that horrendous whine when accelerating. Sub amps generally dont play above 200hz, give or take, and the associated whine would be at a far higher frequency.
Full range amps are another story, it is a must.
Old Dec 27, 2007 | 10:31 PM
Neutered Sputniks's Avatar
Grounding them at the same spot or grounding them separately is the same, as long as any ground point has <4 ohms resistance to the negative battery terminal.
Old Dec 30, 2007 | 06:28 AM
Doug1627's Avatar
Cool, Thanks guys.
DangerZone9K
Mar 28, 2012 07:40 AM
DangerZone9K
Feb 19, 2011 12:49 PM
chanjunc
Feb 17, 2011 09:37 PM
philipf22
Feb 23, 2006 01:54 PM
AndyS2
Jan 14, 2004 05:39 AM
