Grounding Head Unit
Old Oct 17, 2011 | 10:16 AM
T-Smac's Avatar
Originally Posted by oth
It's likely an additional ground wire to ground the headunit's case.
You can just attach it to one of the screws that hold the headunit in,
it doesn't need to be the world's greatest ground.
poor ground will lead to higher resistance. Higher resistance can cause all sorts of problems, including sound quality and possibly the unit just plain not powering up. This is an S2000, don't half a$$ the job. Do it right the first time.
Old Oct 17, 2011 | 11:29 AM
stupkid's Avatar
Also your ground wire can burn up. Friend's amp ground wire wasn't grounded correctly and the insulation around the wire burnt off.
Old Oct 17, 2011 | 11:43 AM
Neuman04's Avatar
I have it grounded to the car harness ground wire.
Old Oct 17, 2011 | 12:03 PM
iDashX's Avatar
That's a good ground to use because its the oem. Some units may require a 2nd ground (e.g. in dash video)... I used a sheet metal screw and screwed it to the sheet metal under the knee pad of the passenger side.
Sent from my MB860 using Tapatalk
Old Oct 17, 2011 | 12:35 PM
T-Smac's Avatar
Yes high resistance = high heat as well, which can burn up insulation, but will usually cause the other problems first. Your friends problem might have also been in combination with too small of a gauge of wire for the ground.
Old Oct 17, 2011 | 04:54 PM
oth's Avatar
oth
I had assumed this was an additional ground wire to separately ground the case,
which would not normally carry current; however I just checked the Sony installation
instructions, and see that it is the only ground wire.
The easiest thing would be to splice it to the adapter harness' ground wire,
thus grounding it through car's harness to a factory ground point.
Old Oct 17, 2011 | 05:41 PM
Neuman04's Avatar
Thats What I eventually did... much easier
BlueTeg
Apr 18, 2018 11:34 AM
demonkey
Bay Area For Sale
May 21, 2013 08:38 PM
Stolen R
May 27, 2006 08:35 AM
alex.stanley
Nov 5, 2005 02:10 PM
bs-inc.s2k
Sep 20, 2005 09:12 PM
