Head Unit Advice
Old Jun 2, 2014 | 07:51 AM
DrakeValle's Avatar
Default Head Unit Advice
I've never really been into changing much a my car's audio systems, so I'm about as close to a noob as it gets when it comes to this.
My car already has a head unit installed, but I do not like it. It has very bright blue or red lighting, and does not interface well will my Android phone.
So I am looking at replacing the head unit. Below is the one I have my eye on.
http://www.pioneerelectronics.com/PU...ers/MVH-X560BT
I like it because it seems to interface well with iPhone/Android via Bluetooth or USB. It also has the ability to change colors so I can change it to an orange that is close to the OEM dash cluster. I plan on pairing it with a Modifry DCI.
I also want to use this (https://www.modifry.com/products/mou...vise/index.htm) with a universal phone mount.
Anyone else using this head unit? I'm guessing I will have to splice the wires because I'm sure that's how the previous owner installed the existing unit rather than using a plug and play adapter. I'd be half tempted to resplice an OEM connector back on if that is feasible/possible to regain plug and play.
Thanks
Old Jun 2, 2014 | 08:30 AM
S2K.01's Avatar
Check out my thread here:
https://www.s2ki.com/s2000/topic/108...eo-head-units/
I'd suggest using the modifry dci. Their site has links to compatible head units here:
https://www.modifry.com/products/dci...patibility.htm
I chose a head unit with a rear usb so I can run the cable to a more convenient location and close the radio door.
Old Jun 2, 2014 | 08:47 AM
DrakeValle's Avatar
The unit I posted has rear USB and AUX connections. I looked at the one you posted and it doesn't seem bad, but I don't need the ability to play CD's. Thanks for the input.
Old Jun 3, 2014 | 07:01 AM
takeshi's Avatar
No reason it couldn't be done. Would probably be a better long term solution.
Old Jun 3, 2014 | 12:42 PM
DrakeValle's Avatar
Yeah, that way if I decide to switch head units later I don't have to be redoing the wiring again. I'll have to see about getting a connector.
Old Jun 4, 2014 | 09:06 PM
F1_DNA's Avatar
Same head unit I am looking at. Should work perfect with the Modifry adapter! It's funny to me, because the last time I bought a stereo was about 4 or 5 years ago and it was MORE expensive to get a head unit without a CD player. In 5 years I think 1 CD has gone into mine. I'll be happy to get more available screen space as a trade off for something I will NEVER use again.
Old Jun 5, 2014 | 08:19 AM
DrakeValle's Avatar
I ended up ordering the headunit and all the modifry goodies.
It'll get here Monday, but I probably won't get it installed until I get an OEM radio connector, but I will report back with a review.
Old Jun 5, 2014 | 12:24 PM
oth's Avatar
oth
If you did not order a harness with your DCI from Modifry, either plug&play or conventional,
you should - unlike many generic adapter harnesses, Modifry's has the s2000-specific dash switch
and mute wires.
Old Jun 10, 2014 | 11:21 AM
DrakeValle's Avatar
Got everything installed Saturday. So far I'm liking it, but I really need a quieter exhaust in order to really be able to listen to music. I like being able to adjust volume without needing to open the radio door. Setting the backlight color to amber gives it a very close match to the oem dash in lower light. During the day with top down it color washes out and looks red.
Also, a complaint I read in most reviews was that its almost impossible to read the display during day. This is indeed true, the gloss face plate glares very badly. I am going to try and apply a anti-glare screen protector and see if that improves readability.
My biggest complaint about my whole setup now, is the dash mount that I got for my phone. The phone holder from Modifry is great, but I chose this mount: https://www.modifry.com/products/mou...vise/index.htm
I had to do some modifying so that the radio door could open/close without hitting the phone holder, which made the phone almost angled at the passenger and too far away to read. I will probably be ordering the other dash mount from Modifry.
Old Jun 13, 2015 | 11:49 AM
Irukandji's Avatar
Does the Mute button on the dash function with this head unit? Does it fully mute, reduce volume, or pause when connected via bluetooth and/or USB to phone/ipod?
Thanks!
-Greg
japcrap
Jul 6, 2015 03:24 AM
J1mmys
Jul 30, 2013 08:53 AM
llckll
Mar 11, 2011 12:36 PM
trivium
Jun 24, 2006 12:36 PM
