Headlight Issues
Old Oct 13, 2023 | 05:36 PM
Haika7x's Avatar
Default Headlight Issues
Hey guys,
I have checked the forums and I can't really find any fixes on here,
I've recently repainted the car and I've been having issues with the driver side HID light. When you turn the car on, both headlights might work but if you switch the lights of and then on again, the driver side light doesn't turn back on.
I bought a brand new OE replacement ballast, changed the Relay, switched the bulbs (still not working with "good" bulb), changed the 20A fuse and nothing fixed it.
Please help.
Old Oct 14, 2023 | 05:38 AM
Kyle's Avatar
Originally Posted by Haika7x
Hey guys,
Please help.
Repainted? Check the grounding points on the headlight harnesses aka in the engine bay where all of those exposed wire/ring terminals mount in the front fender area. If those aren't making a good connection to bare metal you may have issues.
Old Oct 16, 2023 | 03:11 AM
Haika7x's Avatar
Thanks Kyle,
We never touched the engine bay since the car was just resprayed the same color. i forgot to mention that we checked the ground on the fusebox.
Old Oct 16, 2023 | 06:53 PM
spider2k's Avatar
Active Streak: 30 Days
Thanks Kyle,
the lights don't ground at the fuse box.
Old Oct 16, 2023 | 10:24 PM
Haika7x's Avatar
Thanks, where do they ground? I can check that too.
Old Oct 17, 2023 | 07:12 AM
spider2k's Avatar
as noted above by Kyle, the grounds are in the front corners towards you. look for the holes where the harness goes into the fenders. the grounds are nearby.
also check all of the connectors for burnt/melted pins.
R23USS
Apr 13, 2018 10:43 PM
shkani04
Dec 5, 2011 04:49 AM
wbp666
Jun 12, 2008 10:14 PM
SwansS2K
Nov 7, 2006 02:53 PM
sthestazn
Aug 24, 2006 06:10 PM
