Headunit Install Problem.
Old Dec 27, 2006 | 12:08 AM
tbonesteak's Avatar
Default Headunit Install Problem.
Hey guys, I am in the middle of installing the headunit and i am stuck on two things:
1. I hooked up my pioneer Deh-7800mp and out of the four rear speakers (two on each rollbar), only the right ones from each rollbar come on. The two left speakers, one from each rollbar does not work. Anyone have a solution to this?
2. The headunit just will NOT go in all the way so i can screw it to the mounting bracket. It gets stuck with about half an inch left to go and will not go in any further, causing the headunit to stick out and unable to screw it in.
Can anyone help me with these problems? Help is greatly appreciated. Thanks in advance.
Tim
Old Dec 27, 2006 | 05:19 AM
Dave-ROR's Avatar
1. Check your rear-left speaker wiring, there's a problem with it.
2. arrange the wiring harnesses along the far back and side of the compartment, the HU will go in. I shortened my harness to help alleviate this problem and it helped, but didn't completely solve it. You just have to use the space available around the compartment wisely
Old Dec 27, 2006 | 08:08 AM
tbonesteak's Avatar
thank you. i will check that. ANyone else with suggestions? THanks in advance.
Old Dec 30, 2006 | 01:32 PM
pikkashoe's Avatar
1. Cant help you with the speakers, maybe check the polarity, also check to see if the left ones are not blown, connect them to where the right ones are connected. Or it could be the radio as well, maybe the left channels are blown.
2. you really have to push the wires in there, it can be done, I had the radio, with the DCI board.
2SoonS2K
17
Oct 18, 2012 03:39 PM
JspecVtec
Sep 28, 2007 05:34 AM
ImBatman
Mar 23, 2006 07:27 PM
tron1
Mar 2, 2004 07:46 AM
Tanqueray
Mar 8, 2002 02:50 PM
