Help with alternate source of Switched 12V power
Old Feb 24, 2011 | 01:38 PM
DocS2000's Avatar
Default Help with alternate source of Switched 12V power
Everybody-
I have a Kenwood KDC545U headunit that I love, but the remote turn-on wire in back seems to be a dead end. It does not send any voltage to the amplifier to have it switched on. Is there another source of 12V keyed power that I can tap into for the remote turn-on wire to my amp?
I thought of the wire to the rear 'cigarette lighter', but I believe it is probably a constant 12V, no?
Thanks
Doc
Old Feb 24, 2011 | 02:29 PM
iDashX's Avatar
cigarette lighter should work. It is only active if the key is in the ACC position. Did you try going through the menu to see if the remote lead got turned off?
Old Feb 25, 2011 | 09:25 PM
DocS2000's Avatar
I did check the settings. Everything looks ready to go in that department, thanks.
Old Feb 28, 2011 | 09:49 PM
Ragnarok043's Avatar
try the acc wire from the headunit, i believe its the white/red wire on the factory connector.
Ap2low
Jan 15, 2015 05:10 PM
s2kmaniac81
Dec 21, 2005 12:50 PM
mr_grand_prix
Dec 15, 2005 08:29 PM
LiQUiD iCE
Apr 12, 2005 06:20 AM
KLN
Dec 31, 2004 12:48 PM
