Help! Amplified speakers has no sound when playing OEM CD
Old Nov 29, 2001 | 04:45 PM
scs2000's Avatar
Default Help! Amplified speakers has no sound when playing OEM CD
For some reason after I installed amplified for my speakers, no sound comming out when I play the OEM CD player. When I switched to radio the speakers work fine. Please help. Thanks
Old Nov 29, 2001 | 04:50 PM
FULLTHROTTLE's Avatar
If you used the antenna amplifier output to power the amp it wont work on CD because the antenna amp turns off when the CD is used.
You will need to set up a manual switch or power the amp with the ignition somehow.
Old Nov 29, 2001 | 08:06 PM
lucid's Avatar
Yes sounds like the remote lead was tapped to the antenna. Use an PAC OEM-2 as the line converter it has a built in trigger for an amp. If you don't want the converter a PAC TR-4 Trigger will do the trick. I can get you either unit if you need it. But i wouldn't go any other route.
Old Nov 29, 2001 | 08:14 PM
jzr's Avatar
jzr
Sounds like you definitely used the antenna lead - I did the same thing on accident once too. There's a 12V accessory lead in there somewhere (I forget the color) that'll do the trick. Get a voltmeter and find the wire that goes from 0 -> 12V when the key is turned to the accessory position with the stereo off. Wire it to the remote lead on your amp and you're set!
Old Nov 29, 2001 | 08:58 PM
lucid's Avatar
you can directly connect it but a trigger will avoid popping
Old Nov 30, 2001 | 08:05 AM
scs2000's Avatar
Thanks for your helps Guys in finding the problem. I did bought Lucid's PAC OEM-2 and now my CD is working fine. Again thanks for the help.
Old Dec 13, 2001 | 06:42 AM
nEVERCLEAR's Avatar
I'm a little embarrased to say that I did the same thing and actually got pissed at the stereo shop guy for sending me back a defective head unit. I had to have it repaired under warranty and thought they had forgetten to hook up the internal wires for the cd signals. Oooppppppppssssssssssss
WayneCallar
Feb 23, 2013 08:46 AM
Gerald28
Jan 28, 2007 07:13 PM
B.C.
Jan 1, 2006 10:52 PM
gosixers215
Aug 12, 2005 11:14 AM
docbry
Mar 29, 2004 12:50 PM
