New headunit & amp, keeping speakers and changer?
Old Feb 19, 2013 | 12:32 AM
WayneCallar's Avatar
Default New headunit & amp, keeping speakers and changer?
How do I keep the CD changer working when I put my new Sony headunit in?
Also will I wire the roll hoop speakers in as rears? I'm hoping to keep these just fade them so they are at a low volume so that I don't blow them when cranking up my new competant speakers!
How did you keep your RCA's seperate to your power line? Either side of the car would be a bit of the pain? Or perhaps side of car and along the middle somehow? (Amps going in boot)
Thanks
Old Feb 19, 2013 | 05:19 AM
oth's Avatar
oth
AFAIK there is no way to keep the OEM cd changer with an aftermarket headunit. While
theoretically possible to create a protocol converter, it wouldn't be commercially viable.
As for wiring, it's easy to run wires down either of the sills, and possible, though a little
more work, to run them down the center console.
If you do a forum search on "running wires" you'll find many, many helpful posts.
Old Feb 19, 2013 | 05:29 AM
JD NC's Avatar
Thanks
Not aware of any CD changer adapters that will work with your particular setup, but they do exist for other older hondas and other HUs, like for a 1990's Odyssey and older alpines, for example. Google mostly came up with adapters for hooking up an ipod to the changer port, so your best bet is probably to call a local shop that does stereo installs and see if such a harness still exists, and for which HUs. If it exists, it is probably a simple plug an play adapter. What model Sony are you putting in?
Old Feb 22, 2013 | 08:07 AM
Thanks guys! I think i'll just take the CD changer out then!
How do I keep the rear headrest speakers?
Old Feb 23, 2013 | 08:46 AM
steven975's Avatar
the rear headrest speakers should just wire up to any amp, though I think to an amp is kind of a waste...I'd just go to the head unit. It's pretty much like any other car speaker.
Neuman04
Oct 12, 2011 04:30 AM
blacks2k
Jul 9, 2005 05:01 PM
AlanL
Mar 28, 2005 09:15 AM
docbry
Mar 29, 2004 12:50 PM
LILRED2
Jun 3, 2003 05:30 PM
