Help with Install
Old Oct 4, 2004 | 07:40 PM
nMeOnE's Avatar
Default Help with Install
Ok i finally got all the equipment i needed..
I got a JL audio 10w6 and a Jl 450/4 with two JL audio 6.5 for the door panels
JL all the way.. cept for the stock headunit which i will use the line output converter
I'm planning to bridge channel 1and2 for the sub and channel 3&4 for the door speakers..
Should i use the 4 channel LOC output or the 2 channel LOC output for this setup?
Any suggestions on how to connect the line output converter to the headunit then into the amp would be good
Old Oct 5, 2004 | 04:16 AM
SCoach's Avatar
You bought all JL equipment and you're going to run it all with a stock head unit? That's like buying a racing car and running it on all-season radials.
Old Oct 5, 2004 | 06:23 PM
nMeOnE's Avatar
Common at least give me a break i'm still in highschool and only work like 20-22 hours a week.. plus the Stock HU so i can keep the DCI
New cd player is like 300-400+100 for DCI
So should i get the 4 channel line converter or the 2 channel for my setup?
Old Oct 6, 2004 | 06:57 AM
SCoach's Avatar
High School?! Okay, I guess I can cut you some slack then!
I still think you're going about this the wrong way, but reverse logic seems to be the thing with today's youth.
I don't know anything about the output converters so hopefully someone else could help you there. I just hope you like what you get with all this stuff.
I wouldn't mind having those JL 6.5s myself.
Old Oct 6, 2004 | 08:02 PM
nMeOnE's Avatar
Does anyone have a 00-01 S that has a system with a stock HU that could give me some pointers on how to install this? I'm planning to tap into the two unused rear speakers line on my 01 HU and getting a line out converter to get both the rear and front channel into my amp which will power the JL subs and speakers
Suggestions and tips would help alot thx
sodaking663rd
Sep 28, 2006 06:02 PM
Miike505
Sep 7, 2005 05:57 PM
jackhoff
Oct 25, 2003 11:47 AM
Ubetit
Oct 17, 2002 08:26 AM
yoweichang
May 27, 2002 07:54 PM
