HELP WITH KEYLESS ENTRY MOD (Reversing it)
Old Mar 28, 2013 | 04:00 PM
s2k Prodigy's Avatar
Default HELP WITH KEYLESS ENTRY MOD (Reversing it)
OK. so this is the issue. I cut the cables that disabled the keyless entry from working while the key was in. Fast forward, i lost my keys, and a friend was kind enough to give me a spare FOB he had. Problem is, i am unable to program the remote because of the previously cut cables ( i was inexpeirenced and cut the cables way too short)
all in all, i cant program the keyless and im stuck using my key to open the door, and was curious if i would need to buy a new hardness, OR if someone could instruct me how the hell the remove the short bit that still in the keyless module and how to replug the remaining cable in. Im not too savy with electronics, so i wanted to post it here before i commited to somthing.
thanks in advance.
Old Mar 28, 2013 | 07:30 PM
s2kt3's Avatar
Undo the connector and pull the pins out, and extend the wires then re install the pins
Old Mar 28, 2013 | 07:49 PM
how would i pull the pins out? i can get the harness off an all, but is it as simple as just pulling the wires out?
Old Mar 29, 2013 | 04:32 AM
s2kt3's Avatar
U need a small needle type thing, pop the connector lock open should be white, then u need to insert the needle and unclip the pin from the connector, it's a bitch so be patient!!!!!!
Gl
Lee
Old Mar 29, 2013 | 06:03 AM
thanks man, ill give it a shot this afternoon.
Old Mar 29, 2013 | 02:59 PM
got it! thanks alot. i redid the cables this time around to make it easier if it arises again. great mod nonetheless.
Old Mar 30, 2013 | 06:23 PM
s2kt3's Avatar
Good stuff !!! A bitch but an easy fix more or less !!!
Cyclon36
Apr 26, 2018 09:06 PM
s2k Prodigy
Mar 29, 2013 05:21 PM
crank
Dec 23, 2012 12:59 AM
ED1
Dec 23, 2005 02:35 PM
HOTRODS2000
Nov 29, 2004 12:32 PM
