Help with Tweeter Install (Polk MMC6500)
Old Dec 7, 2007 | 07:14 PM
gtg749m's Avatar
Default Help with Tweeter Install (Polk MMC6500)
first....i got a 2002 s2k
I just purchased the Polk MMC6500 and while trying to install the tweeter ran into some problems.
Maybe some MMC6500 users can chime in
First pic shows how it comes, basically with its on tweeter pod
Second pic shows how its mounted and glued in there.
Ive tried to mount them with the pod which was too big.
Ive read the install FAQs and it never mentioned anything about aftermarket tweeters coming with its own pod. Im kinda scared to try to break the Polk tweeter pod and damaging the tweeter.
Anyone have any suggestions?
Old Dec 7, 2007 | 07:33 PM
Neutered Sputniks's Avatar
Use a dremel, carefully dremel away just a little on each side so it fits the stock mounting posts. If I get a chance, I'll take my door panels off and get pics of mine so you can see what I'm talking about. The outside plastic bit is okay to be dremeled, but I wouldn't try taking it all the way apart.
Cheers!
Old Dec 8, 2007 | 12:26 PM
IShift@9v2's Avatar
Banned
Correct me if Im wrong, but the pic is the base tweeter itself, which can be snapped into the surface/flush and angle mounts? This allows the user to swivel the tweeter inside each respective mounting cup. Did you get these new? If not you are missing the mounting pods/cups.
Polk uses a compression type fit, which allows you to swivel the tweeter for aiming purposes.
Old Dec 8, 2007 | 02:00 PM
gtg749m's Avatar
Cheers!
thanks! this is waht i did and worked well
Old Dec 8, 2007 | 02:50 PM
Yeah, but the problem is that the 1inch tweeter is too wide to fit between the stock mounting posts. My Diamond's are the same way. A little dremel work does the trick
Glad to see it worked out for the OP
sanjay
Apr 7, 2010 07:29 PM
rad23racer
Mar 4, 2006 07:46 PM
s2ooohims
Oct 16, 2005 07:52 PM
Gantra
May 9, 2003 05:01 PM
chardo
Aug 15, 2002 03:30 PM
