Help w Viper alarm system problems
Just recently my alarm doesnt seem to want to arm or disarm on the first try. I have to push the arm button maybe 10 times to get it to arm... when it doesnt arm it beeps back at me sayin like its out of range. If i try to open the trunk from the remote it works every time though. There are new batteries in the remote. Any suggestions?
perhaps you have a loose connection for the ground/power for the doorlocks.
The trunk pop works because it runs off its own relay (similar to the door lock relay) which has its own powersource and ground.
Tried several batteries. Only have one remote. The car battery is 2 years old and starts the car fine. I wouldnt have a loose connection because the alarm doesnt even arm... or even communicate with the remote..
i've had the alarm for 3 years... it just started doin this in the past month or so. if i push the lock button several times.. sometimes 10 sometimes 20... then it locks.... or unlocks depending on which button im pressing
If you're resigned to a new remote, try taking apart your current one and look for any corrosion on the battery leads. Even if you don't see any, try rubbing the cntacts and battery and apply a little wd-40. I had an Alpine fob that I had to keep WD-40'd internally to keep corrosion from building up and making my fob work intermittently.
i took the remote apart... found out that there is a 3 pin connector that broke at the solder points.. i just resoldered the connections and it works perfect. Thank everyone for narrowing it down to the remote.
s.hasan546
Dec 14, 2008 07:07 PM
