Help w Viper alarm system problems
Old May 15, 2007 | 02:04 PM
myflys2k's Avatar
Default Help w Viper alarm system problems
Just recently my alarm doesnt seem to want to arm or disarm on the first try. I have to push the arm button maybe 10 times to get it to arm... when it doesnt arm it beeps back at me sayin like its out of range. If i try to open the trunk from the remote it works every time though. There are new batteries in the remote. Any suggestions?
Old May 15, 2007 | 03:10 PM
Saki GT's Avatar
Try different batteries again? Do youhave other fobs that you can try? Maybe the cpu needs to relearn the fob? How old is your car battery? Maybe its getting weak with age?
Old May 15, 2007 | 05:44 PM
GrandMasterKhan's Avatar
perhaps you have a loose connection for the ground/power for the doorlocks.
The trunk pop works because it runs off its own relay (similar to the door lock relay) which has its own powersource and ground.
Old May 15, 2007 | 06:14 PM
myflys2k's Avatar
Tried several batteries. Only have one remote. The car battery is 2 years old and starts the car fine. I wouldnt have a loose connection because the alarm doesnt even arm... or even communicate with the remote..
Old May 15, 2007 | 06:16 PM
revhi's Avatar
Which Viper system? Theres usually a delay with the lock and unlock, push it and wait a second. Trunk pops everythime cause your holding the button down.
Old May 15, 2007 | 06:49 PM
myflys2k's Avatar
i've had the alarm for 3 years... it just started doin this in the past month or so. if i push the lock button several times.. sometimes 10 sometimes 20... then it locks.... or unlocks depending on which button im pressing
Old May 16, 2007 | 04:43 AM
revhi's Avatar
Its either the remote or alarm antenna. Most likely remote. They dont last that long.
Old May 16, 2007 | 12:18 PM
myflys2k's Avatar
thanks... gonna start with a new remote
Old May 16, 2007 | 12:24 PM
Saki GT's Avatar
If you're resigned to a new remote, try taking apart your current one and look for any corrosion on the battery leads. Even if you don't see any, try rubbing the cntacts and battery and apply a little wd-40. I had an Alpine fob that I had to keep WD-40'd internally to keep corrosion from building up and making my fob work intermittently.
Old May 16, 2007 | 03:53 PM
myflys2k's Avatar
i took the remote apart... found out that there is a 3 pin connector that broke at the solder points.. i just resoldered the connections and it works perfect. Thank everyone for narrowing it down to the remote.
s2krazy01
Apr 19, 2009 09:51 PM
s.hasan546
Dec 14, 2008 07:07 PM
Suzybee
May 2, 2006 07:41 AM
Insert Name
Jun 19, 2005 07:37 PM
gmans2000
May 15, 2005 07:10 AM
