hey guys - why would my sub cut out?
Old Nov 2, 2004 | 06:37 PM
Bass's Avatar
Default hey guys - why would my sub cut out?
JL 12 w3 dual coil inch sub - not feeding it too much power and when it doesn't cut out it pumps pretty good BUT when it's kind of loud the sub will just cut off - wiring is fine - amp is not hot????
x/over settings set at 60 and less than .5 ohms feeding the thing
any idea on things i could check before i send the sub back
Thanks
Old Nov 3, 2004 | 02:22 AM
S2KSuzuka's Avatar
Check the ohms on the sub with a multimeter. If the amp shuts off when you are playing it loud the amp is probably going into thermal shut down. How is it wired> is the amp bridged. if so that may be the problem. when an amp is bridged it sees half the ohms. for example. if you have a 4 ohm woofer and the amp is bridged the amp see a 2 ohm load. if the amp is desinged for a 4 ohm load it would get hot and shut down, then it would cool off and play again.
If you used an 8 ohm woofer it would see 4 and work fine. If you have a dual voice coild woofer you may be able to change the way it's wired to change the ohms.
hope that helps
Mitch
Old Nov 3, 2004 | 02:54 AM
Bass's Avatar
Thanks Mitch
it's a dual voice coilbut we are running only one bridged channel from the amp and then there are jumpers on the sub
Old Nov 3, 2004 | 04:48 AM
S2KSuzuka's Avatar
Is your sub wired series or parallel?
check the ohms with a meter. if it's 2 ohms then the amp will see 1 and shut off pretty quick
you may have to wire it in series, that would change the ohms (impedence) to 8 and the amp would see 4. of course it depends on your amp , and what load it can handle
Mitch
Old Nov 3, 2004 | 04:55 AM
MacGyver's Avatar
Steve,
Who installed it?
Old Nov 3, 2004 | 06:49 AM
Bass's Avatar
I'm not saying BUT - Glenn knows his stuff - i'll test it out with a meter tonight - thanks again Mitch!!
Old Nov 4, 2004 | 08:01 AM
afetsman's Avatar
It's possible the x-over could be going bad.
Hickey322
Mar 30, 2010 06:37 AM
crav3s2k
Jun 10, 2008 07:50 PM
User 71524
Jun 14, 2007 11:11 AM
Drinks2k
Mar 19, 2007 04:35 PM
SilverstoneS2k_FL
Feb 21, 2005 04:36 PM
