High beam indicator
Old Jul 1, 2007 | 07:58 AM
2004S2000's Avatar
Default High beam indicator
The high beam indicator in my dash (07) that also serves as the daylight running light indicator is not coming on. I keep blinding people. I have had an alarm put in recently. Could it be that a connector has come loose, are there individual connectors back there, does the whole display need to be replaced. If it's just a loose connector I'd rather do it myself than go to Honda so they can bitch about the alarm, Etc. Also, how do I access the cluster to fix this?
Thanks in advance!
Ken
Old Jul 4, 2007 | 07:54 AM
imdarkrider's Avatar
set your alarm off , and see if they hooked up to the light wires instead of the parking light wires... if they hooked up to your lights see if it's your brights or if it's your normal day time lights if it's those then they screwed something up , if it's the parking lights just remove the steering colum (3 screws) unclip and check to see if the harness is plugged in. should be on the right side on yours
Section38
Apr 19, 2017 07:59 AM
Carbon Blue
Feb 5, 2012 11:44 AM
sanchoii
Jul 12, 2011 06:59 PM
2004S2000
Jun 30, 2007 10:24 PM
ShaneS2K
Sep 1, 2006 06:45 AM
