home stereo help
Old Jan 7, 2004 | 01:43 PM
HKStallion's Avatar
Default home stereo help
I got a Samson servo 240 2 channel amp from work for my home theater, problem is, i have a receiver that outputs unbalanced audio over composite rca cables. the amplifier inputs are balanced 1/4" TRS. Can i use this cheaply or is it a lost cause. i can get a matching 2 ch amp for $300.
thanks
Dave
Old Jan 7, 2004 | 10:29 PM
NFRs2000NYC's Avatar
Dave, PM Phil, PJK3.........he knows alot about this stuff......hell help you out!
Old Jan 8, 2004 | 08:48 AM
PJK3's Avatar
hrm... i show the servo 260 offers RCA inputs... bummer. and i can't find the manual for the servo 240 online on the Samson site.
yes, you should be able to use this, you will either need to make some balanced to unbalanced adapters or have a local music shop make them for you... i would suspect a local shop would make these (if they don't stock them) for something like $20-$30 each pair.
according to the Samson Servo 260 manual:
[QUOTE]7: Balanced input connectors (left/right) - Connect incoming signal to these electronically balanced 1/4" TRS (Tip/Ring/Sleeve) jacks, wired as follows: Tip hot, Ring cold, and Sleeve ground. Use balanced three-conductor cabling and TRS plugs wherever possible (unbalanced two-conductor plugs can also be inserted into these inputs, but you
Old Jan 8, 2004 | 01:42 PM
HKStallion's Avatar
Thanks, I'll give a music shop a try. Soldering is not really my thing.
appreciate everyones help
Dave
Old Jan 8, 2004 | 07:02 PM
PJK3's Avatar
np.
you'll probably need to find a music shop that doesn't just do instruments, but someone that carries mics, sound boards, mixers, amps, etc.
RBC3
Feb 22, 2007 08:46 AM
Bo_vien4
Jan 29, 2004 08:00 AM
B.C.
Dec 26, 2003 07:25 AM
tyler
Oct 23, 2002 10:18 PM
steve73172
Aug 16, 2001 03:18 PM
