Honda Navigation System
I have an import S2000 AP1 - 1999 - It has a "Honda Navigation System" fitted that is not working. The issues are as follows:
1: The display is broken.
2: The DVD player from the boot is missing.
I would like to keep the car in as an original state as possible.
Has anyone got any suggestions please for the following:
A: Where I could source a new, complete, Honda Navigation System.
B: If not OEM, what's the next best please.
C: A really top notch replacement that requires no DVD player. But bear in mind, I guess, the depth of the S2000 Navigation System.
If you guys can't help then I guess I'm stuffed
Quite a few threads on this in the UK section:
https://www.s2ki.com/forums/uk-irela...update-635390/
https://www.s2ki.com/forums/uk-irela...s-deal-501041/
https://www.s2ki.com/forums/uk-irela...-bezel-759430/
and one from this section:
https://www.s2ki.com/forums/s2000-el...cation-837298/
Re-newing this conversation as I have finally got around to removing the broken system (a lot easier than I thought it would be)..... I have completed some measurements as follows:
18 CM width ---- 7.08661 Inches
6.5 CM depth ----- 2.55906 Inches
10.5/6 height ----- 4.17 Inches
Seems like the following could be a good fit, although not the original (I can get hold of the original but with Japanese mapping)
https://www.eurocarparts.com/ecp/p/c...kaAoPdEALw_wcB
My only question is:
Do I just need the unit or do I still have other requirements (A friend said something about a player in the boot) ..... ?
Wiring etc etc
Thanks
Wiring etc etc
Thanks
Last question for this, I hope
I have sourced and purchased a new console screen replacement for an AP1 Nav system ….. A friend of mine stated that something in the boot may also be required (which I think is missing ---- maybe a DVD player or something that holds the storage of the maps)…. Also, this replacement unit states the following in the description:
This is a Japanese Version Unit and may need updating to work in other countries
Could someone please let me know if the unit will need updating and if so, how?
Also, is there a requirement for something in the boot?
Thank you guys.....
Thank you guys.....
Well, I have received the new part and installed it.... It does not come on when I start the engine, however this could be due to a couple of reasons:
1: There is no CD Changer in the boot - I have just ordered an OEM one, so that may do it (If I can work out the wiring
) -- Still would have thought it would have at elast powered on.... but that leads me to point 2...
2: With the bundle connector behind the Sat Nav on the dashboard, there is one Red Wire that has snapped.... As this is a red connection, I am making a bet that it may be something to do with the power (but that's just a guess)
If anyone has any Honda Sat Nav cabling diagrams or any experience with fitting these systems, would be great if you could post here....
Thanks guys
) -- Still would have thought it would have at elast powered on.... but that leads me to point 2...2: With the bundle connector behind the Sat Nav on the dashboard, there is one Red Wire that has snapped.... As this is a red connection, I am making a bet that it may be something to do with the power (but that's just a guess)
Thanks guys
