how to get Doors to Unlock with ignition ?/Prob
Old Jan 7, 2008 | 02:34 PM
Crusin_x1's Avatar
Default how to get Doors to Unlock with ignition ?/Prob
Hi, I'm new to the S2000, I have a new 2008. Love the car.
It use too when I turned the ignition off that both doors would unlock. This no longer happens and it stopped working after an Alarm install.
Both doors do lock when I turn the key on, if there closed. also unlock fine with the keyless
The Alarm is an Omega AL-100F and piggy backs to the existing OEM alarm. So I keep the oem keyfobs
The guy that installed the alarm said he didn't cut anything, he just tapped into the wires.... He don't know why that happened but I am taking the car back for him again to try and fix the prob, but in the mean time....
Is the door unlock thing a programmable feature of the oem alarm or the keyless entry or is the new alarm to blame?
And I called a few Honda dealers and some say it doesn't have that option and others just say look in the owners mann.. witch I did and didn't see anything..
Can anyone help?
Old Jan 7, 2008 | 02:59 PM
MikeyCB's Avatar
Well I don't know if this will shed light on anything, but my CompuStar alarms (on other vehicles, including 1 Honda Civic) added that feature to the vehicle. The alarm sensed when I started and shut down the car and locked and unlocked at the right times for me.
I suspect the Omega does not have this functionality but had overridden the factory alarm so you it no longer does this for you. That's my only guess.
No doubt there is some sort of optional alarm module that could do this for you since they have everything else including window roll-up and down modules.
Old Jan 8, 2008 | 02:21 PM
HankookS2K's Avatar
i think it may be because its a piggy back unit. I know when i installed my viper into my my01 it unlocked both doors when i turned the vehicle off and also locked after the vehicle has started.
Im not familiar with your unit of alarm because i only install DEI products, but its just probably because of the unit. but its kind of weird if it used to do it from factory and now it wont.....
Old Jan 9, 2008 | 05:27 PM
S2K2XGA's Avatar
Locking and unlocking doors from the ignition is an option on most alarms, I have an OEM alarm on my05 and it doesn't have that option, neither does my05 Pilot, but my OEM alarm on my 07 IS does.
Override sounds like the problem as said before. The guy that hooked up the alarm should be able to fix it. Honda Sub-Contracts out their Alarm installs therefore does not know about them.
Old Jan 10, 2008 | 07:32 AM
Crusin_x1's Avatar
Well, I know that the Omega Alarm has the ability to unlock and lock the doors with the ignition. But that feature was not connected because the car did this before the Omega Alarm....
I did get a little info about the OEM Honda Alarm; there is a manual switch on it that changes the function of the locks. However I don't know where this is located. It's not under the driver seat.
Maybe the guy that installed the Omega somehow changed this? I don't know, I haven't been able to ask yet.
Old Jan 13, 2008 | 05:53 AM
Crusin_x1's Avatar
It took awhile to figure out, but it turned out to be a simple fix. A loose wire going to the factory keyless entry box from the OEM alarm.
So the omega alarm that was added was not directly the problem.
All is well now.
Thanks for the replies
Old Mar 30, 2008 | 07:54 AM
IlleztImportz's Avatar
so on the early ap1's, after cutting the car off it doesnt unlokc? also when i start it, it doesnt lokc. is it suppose to be like this? (oem alarm)
Old Apr 1, 2008 | 06:01 AM
Mother's Avatar
I'm not sure when they added that feature, because my 2006 doesn't have it from the factory either. My Compustar alarm takes care of that though.
Old Apr 1, 2008 | 08:10 AM
SheDrivesIt's Avatar
My MY04 has no auto lock/unlock features. I hate those things anyway.
starchland
Feb 20, 2009 01:50 PM
Saki GT
Nov 24, 2008 09:54 AM
Verik
Jan 22, 2008 06:14 AM
NoRawkus305
Sep 15, 2007 04:12 PM
